EE Cycleworks has just released their brake for sale. I saw these at Interbike last year and while I thought they looked interesting I didn't think they were attractive. Now, I've completely changed my mind. It doesn't have to do with the fact that they are very small. It is based on the fact that to me they look like they should work really well.... In fact they do.
The complete set was 197grams with pads and holders. Retail price is $520 and that does not include the pads. Colors are silver and black.
Ok, so now that the specs are out of the way, on to the brake. The first thing I noticed about the brakes was the pad installation. A very unique approach. While not identical it reminds me of the old magura brakes where the pads just snap into place. Changing pads requires only your fingers and about 10 seconds. If someone were to be using different pads on different wheels, I'd recommend these brakes based on no other factor than the pad change.
On to the installation. Normally I read instructions, because it's always good to educate yourself as much as you can about whatever it is your riding. However in this case I'm glad I did. Had I just installed the brakes, I certainly would have taken a different approach and would have missed a couple of key elements such as the 7/8" to 1" gap involved in setup. However I did notice that tensioning the cable so it does not rub on the pivot seems to get the spacing close to what is called for, so perhaps that would have worked itself out. I doubt though, that I would have centered the brakes as recommended, which was extremely easy and perfectly accurate(glad I didn't just go at it with a cone wrench.)
Installation is a bit involved and cable housing length is critical. Stiff housing such as flying snakes should probably be avoided. I think these brakes would be a good candidate for Nokon since it never really pushes on a brake. So after trimming my housing 3 times to get the length just perfect, I finally got them setup. But then when tapeing down the housing, the brakes started to bind. It seems that with my bars backside routing(Modolo KX Carbon) and Sram shifters, a kink was created in the housing that bound the cable enough to keep it from returning. Routing the cable on the front side such as most bars would relieved the problem.
I didn't try power cordz on them, but see no reason as to why they wouldn't work. You shouldn't even need the PC clasp as you can wrap it as you would on a derailleur.
I'd recommend if someone isn't patient or skilled in brake installations they may want a good mechanic to do the install. Not that it can't be figured out, but that it might be a bit frustrating.
Once properly installed the first thing I noticed was what felt like a complete lack of friction. It may have to do with the low powered spring, or the bushings, but either way they seriously felt as smooth and effortless as the hydraulics on my mtb. A very good first impression.
The road test. I used yellow swiss stops and Edge carbon rims. The raw stopping power is impressive to say the least. I don't know if I'd go so far as to say it's better than Dura Ace, but I would be very confident to say that it is every bit as strong. But the thing that got me was the modulation. Ok, so it's true lots of brakes modulate well, and some brakes stop well, but not many modulate well on carbon AND have DA amounts of stopping power. These do.
Intentional power slides were no effort, taking me back to my youth, but costing me a new rear tire. Panic stops were amazing. Stopping as fast as anything I've tried but without any sense of being on the edge of locking it up.
All in all I am really impressed with these. I now absolutely love the look of them, it's the look of a brake that really works well.
The only thing I'd question is the strength of the spring. A stronger return spring while it may make the brakes feel a little less surreal would compensate for friction in the cable/housing. It will be interesting to see how much, if any at all, tension is lost from the spring over time. My only other concern is how well or if these will be compatible with some of the newer super wide rims such as Hed and Zipp. With my Edge rims, I ran the setup without spacers, and felt that if the rim was any wider the setup wouldn't work. I'll have to test it out soon.
Next I'd really like to see how the heavier guys like these. Already 3 of our staff have ridden my bike and everyone has come back amazed.
