Any problems in cutting a soldering Ultegra Di2 cables?
Postby Jens » Wed Oct 24, 2012 4:57 pm
Hi,
Yet another Di2 question. :D
As the title goes I would like to know if anybody have had any problems in cutting a reconnect/solder Ultegra Di2 cables? I plan on using the "twist and solder" method and close it all using heat shrink afterwards to seal it off properly.
I would just like to be sure before I take the drill to my non-Di2 frame (It would be a shame to find out myself that it doesn't work after I cut the cables and have drilled holes in the frame :wink: )
TIA
Jens
Cat 3
Re: Any problems in cutting a soldering Ultegra Di2 cables?
Postby WalrusWrench » Fri Oct 26, 2012 6:01 am
Nope.
Just cut, strip, solder, and seal as you would any other wires.
I have done this more than once.
Use adhesive heatshrink tubing to seal it up, IMO.
WalrusWrench
Cyclotourist
Postby Jens » Fri Oct 26, 2012 7:03 am
Thank you very much. Happy to know it is possible without any issues.
Jens
Cat 3
Users browsing this forum: No registered users and 7 guests
cron
