Site Announcements
fairwheelbikes.com/c/topics
Custom Garmin Edge mount
Postby Tillquist » Fri Apr 06, 2012 6:20 pm
It's been a long time since I last posted a message here. But now I'm ready with a new project, a garmin mount specially designed for the 3T stem.
This is the prototype No.1, it is far from finished, but now I have an idea of ​​how it should look like.
Tillquist
Cat 1
Re: Custom Garmin Edge mount
Postby Tillquist » Fri Apr 06, 2012 6:24 pm
Then there is created a version 2 today, it is more stable and robust constructed than the first model.
Tillquist
Cat 1
Postby über-goober » Sat Apr 07, 2012 5:59 pm
Outstanding job!!! :applause: :applause: :applause: :applause: :applause:
I have been using the Barfly and really like it. But your design gets it lower than the stem which I like even better.
über-goober
Cat 2
Postby pritchet74 » Sun Apr 08, 2012 6:05 am
Wow. That's freakin awesome!!!!
pritchet74
Aerodymatic Man
Postby Mike K. » Sun Apr 08, 2012 4:48 pm
That that is one elegant mounting station (the word bracket is too low brow).
Mike K.
Cat 1
Postby Tillquist » Mon Apr 09, 2012 2:52 pm
Prototype 3:
    Weight: 12,8 g
    The 3ed model is now complete.
    The locking mechanism is now machined into the mount.
Tillquist
Cat 1
Postby colorchange » Thu Apr 12, 2012 1:14 am
OK, I want one bad. How much and when?
colorchange
Cat 4
Postby Ypsylon » Thu Apr 12, 2012 7:25 am
Those are really nicely made. Look good, put the display where you can just glance at it and looks a lot firmer and solid than 99% of the other mounts out there. Very well done. Nice weight, too.
They only work for the 3T stem and only for the angle you're using, right?
Ypsylon
Herr Pfennig
Postby Tillquist » Thu Apr 12, 2012 8:27 am
Ypsylon wrote:They only work for the 3T stem and only for the angle you're using, right?
Yes but it's works allso on others stem with 28mm bolts distance.
Tillquist
Cat 1
Postby hanzo111 » Thu Apr 12, 2012 3:37 pm
WOW! That is excellent work. Will you sell these? if so how do I get one.
The purity of the design is what I'm drawn to
hanzo111
Cat 5
Postby colorchange » Fri Apr 13, 2012 2:52 pm
Take my money, Please! How do I order?
colorchange
Cat 4
Postby philolson » Tue Apr 17, 2012 12:41 pm
why not make the front clamp part of the fixture and save a few grams as well
philolson
Cyclotourist
Postby echotraveler » Sat Apr 21, 2012 2:42 am
Hey,
If you consider making a batch. count me in.
VERY HOT!
echotraveler@gmail.com
echotraveler
Cyclotourist
Postby Stolichnaya » Thu May 03, 2012 2:31 pm
This needs to be marketed as "The Enterprise"
Beautiful work. So much so that I am tempted to buy both a 3T stem and a Garmin.
Stolichnaya
Cyclotourist
Postby jdrynberk » Sat May 05, 2012 12:53 am
Will you post a rely soon as to how to buy one these superb mounts??
jdrynberk
Cyclotourist
Next
