Front Center Pull Brake bolt. Need one in Ti or Steel.I have
Postby BMANX » Sun Jan 08, 2012 11:01 pm
I have tried looking at 5 different LBS's as well as google to no luck. Anyone know what I can get this bolt but long enough to use on a front brake. No LBS has ever seen one. Ti would be best but at this point I do not care if it is Ti or steel.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98lbs
BMANX
Cat 1
Re: Front Center Pull Brake bolt. Need one in Ti or Steel.I
Postby Fuchs » Sun Jan 08, 2012 11:16 pm
for wich brake was this one?
i´ve seen it before but that was a while ago. should not be hard to build your own otherwise.
Fuchs
Cat 2
Postby BMANX » Sun Jan 08, 2012 11:24 pm
I can do that but I thought it would be better to use the original. I have the Tektro T726R rear brake but I am using it on the front. I had one longer brake but I am thinking that I might just get some ti bolts and like you have mentioned just make my own.
BIG DADDY B FLOW
BMANX
Cat 1
Users browsing this forum: Google [Bot] and 3 guests
