Masterpiece clamp tuning
Postby UpFromOne » Tue Sep 27, 2011 6:19 am
Just got a Thomson Masterpiece post, 330mm length and 191g. w/ stock steel bolts.
Ordered the titanium bolts & nuts as per usual, but stunned at the massive clamp pieces.
The top clamp piece alone is 33g !
Anyone know a place that makes the clamping parts in carbon, or ti?
Or, has anyone substituted a lighter top clamp from another make?
UpFromOne
Cat 4
Re: Masterpiece clamp tuning
Postby Juanmoretime » Tue Sep 27, 2011 10:05 am
If you search weight weenies there is a guy in Poland that makes a carbon upper and lower clamp for Thomson. When I did mine inclusive of the titanium bolt kit my 31.6 X 330mm setback Thomson was 153 grams.
Juanmoretime
Cat 1
Postby Oilman » Tue Sep 27, 2011 10:38 am
Oilman
Cat 3
Postby BMANX » Tue Sep 27, 2011 4:19 pm
I have his parts on 2 bikes (MTB and Road) and they work amazing. I bought Ti bolts from Toronto Cycles. This brought the weight down a lot.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98lbs
BMANX
Cat 1
Postby UpFromOne » Wed Sep 28, 2011 5:32 am
Great link, thanks! That'll be plan B tho, as just today I ordered a pair of KCNC yokes to try with the stock bottom cradle & ti bolts.
I'll try to post a pic of the post & report after some use.
UpFromOne
Cat 4
Postby UpFromOne » Sun Oct 09, 2011 5:41 am
Here's a couple pics of the modded 330mm post, with black ti bolts. A simple tuning of the top clamp & bolts alone brought it from stock 191g down to 159g. Yes, I used 6mm bolts and ever so slightly reamed out the post holes. I say do what works.
http://img135.imageshack.us/img135/8972 ... clamp1.jpg
http://img72.imageshack.us/img72/6815/m ... clamp2.jpg
UpFromOne
Cat 4
Postby BMANX » Sun Oct 09, 2011 6:18 am
running this on a road bike with aerobars?
BIG DADDY B FLOW
BMANX
Cat 1
Postby UpFromOne » Sun Oct 09, 2011 8:21 pm
A 12.3 lb. fixie. A couple more parts to replace to get into the 11s.
Surprising how fast you can go in a 70" gear, over all types of terrain.
UpFromOne
Cat 4
Postby JLFast » Thu Oct 11, 2012 3:54 am
I see that Smud Products has a 90kg weight limit. Has anyone pushed the limit on this?
JLFast
Cyclotourist
