Site Announcements
fairwheelbikes.com/c/topics
Sram Compatible Down Tube Shifter
Postby bgillis08 » Thu Jul 28, 2011 5:11 pm
Has anyone had any luck pairing DA or Campy DT shifters with Sram Red/Force Derailleurs?
Alternatively has anyone been able to mod Sram TT 500, 900, or R2C levers to fit on standard downtube mounts?
bgillis08
Cyclotourist
Re: Sram Compatible Down Tube Shifter
Postby bikericer » Wed Aug 17, 2011 7:43 pm
Anything that can be run as a friction shifter should work. I know the old 9 speed Shimano TT shifters could be ran either friction or indexed, so maybe there is a down tube shifter as well.
bikericer
Cat 5
Postby andrew9223 » Fri Sep 30, 2011 1:48 pm
I run BTP downtube levers (entire assembly weights under 10 grams) with a Sram red rear derailluer and a 9 speed recon cassette. If you're going to run downtube shifters you owe it to yourself to run friction. Friction just feels good.
andrew9223
Cat 5
Users browsing this forum: No registered users and 6 guests
