Combing DI2 Switches SW-7972 and SW-7970
Postby BikeTech » Fri Mar 11, 2011 5:07 am
Has anyone thought about using both the Sprint and Climbing switches at the same time, connected to the right shifter?
Because only one port is available after the brake lever / shifter is connected, you would need to cut and splice. I don't have the sprint shifter set yet, but I'm thinking about springing for a set and trying it. Shifters on the brake levers, drops and bar tops :mrgreen:
BikeTech
Cat 5
Re: Combing DI2 Switches SW-7972 and SW-7970
Postby Oilman » Fri Mar 11, 2011 9:40 pm
Just solder the wires, it will work for sure.
Oilman
Cat 3
Postby pritchet74 » Sat Mar 12, 2011 5:23 pm
Yup - you would have to solder. As I have mentioned many times before though - custom buttons are the way to go. :wink:
pritchet74
Aerodymatic Man
Postby Jeffr » Sun Mar 13, 2011 11:53 pm
I'm kinda surprised shimano hasn't made a splitter yet. It would've been a nicer solution than two different front wiring harnesses for TT bikes.
Jeffr
The Man in Black
Postby HammerTime » Sun May 22, 2011 4:21 pm
How about using sprint switches as climbing switches? I.e., use the sprint switches on the bar tops. Would they be smaller and more svete, yet still eminently usable?
HammerTime
Cat 1
Postby pritchet74 » Sun May 22, 2011 5:58 pm
Yup, they would work anywhere. I am surprised that we haven't seen that on the Pro bikes yet.
pritchet74
Aerodymatic Man
Postby skimons » Wed May 25, 2011 10:23 am
guess the cable length will not allow you to install them (sprint shifters) far from the levers without cutting the cables?
skimons
Cat 4
Postby colorchange » Fri Jun 17, 2011 1:07 pm
That's what I did, climbing buttons in addition to the more common sprinting buttons.
colorchange
Cat 4
