Tuning my Ridley Damocles
Postby Damo_Rider » Thu Feb 03, 2011 11:22 pm
Well here is the first update on the tuning process.
1. Quick things to remember I am not mechanically inclined so this is basically rocket science to me :grin:
2. Remember a dremel is still a drill so safety is important or you will learn the hard way like I did and drill your thumb :oops:
3. I just started this project yesterday because we have bad weather here in Dallas - this is about 3-4 hours of work (I have two kids and a wife that won't let me work for more than 30 minute at a time)
Tuned Record Rear Derailleur
Steps
1. Cover metal pieces you wish to drill in 2 plies of electrical tape which will help prevent the drill bit from slipping; I learned the hard way one sometimes doesn't work
2. Mark the tape where you wish to drill or else you will get holes all over the place; this is more of an appearance thing
3. I used an 1/8" titanium nitrade coated bit which worked well
4. Start slow and increase the speed to get through the metal
5. Remember to "peck" the drill up and down a couple of times to clean-up the holes.
I still have one large hole on the arm left to drill and I am thinking of painting the metal black - any opinions? If so what kind of prep would I need on the metal and paint? Can I use paint for model airplanes?
Damo_Rider
Cat 4
Re: Tuning my Ridley Damocles
Postby Damo_Rider » Thu Feb 03, 2011 11:26 pm
2nd Update-
This is the other item I have been working on which is much harder than I expected. I have started to sand the entire frame. I have spent about 3-4 hours so far and this is as far as I have gotten. I have been using 120 grit sand paper and found out that no water (as opposed to what people called wet sanding) works faster. You just have to be careful to stop when you start seeing black dust (which is the carbon) and use a wet/damp cloth to wipe the part every so often to check progress. I figure at this rate it will take all of February to complete. :(
Damo_Rider
Cat 4
Users browsing this forum: Google [Bot] and 1 guest
