new project (wheel)
new project (wheel)
Postby concept64 » Wed Jan 26, 2011 12:38 am
here is my new project ....
produce a carbon front hub
My goal and achieve a wheel hub aesthetically beautiful and reliable
the cops in the carbon-carbon axis surely as hybrid bearings
AX rim in 42
radius (if I find .... Pillar of Ti X-TRA)
concept64
Cat 4
Re: new project (wheel)
Postby Ypsylon » Wed Jan 26, 2011 9:15 am
Wow, that hub is gorgeus.
Ypsylon
Herr Pfennig
Postby Boonen » Wed Jan 26, 2011 10:31 am
That looks awesome! HOw do the spokes attach?
Boonen
Faster than Superman
Postby pritchet74 » Wed Jan 26, 2011 7:04 pm
Super sexy. Meow...
pritchet74
Aerodymatic Man
Postby dunlinii » Wed Jan 26, 2011 7:39 pm
That looks amazing, if you are drilling the spoke holes, pics please!!
dunlinii
Cat 1
Postby concept64 » Wed Jan 26, 2011 11:39 pm
Boonen wrote:That looks awesome! HOw do the spokes attach?
hi many thanks
This is the first step I weighed just to see
it remains to install the part that keeps the bearing is the radius
this piece is the most important because it keeps the ball bearings in the same axis as the nipples
on this picture you can see the room
concept64
Cat 4
Postby concept64 » Thu Jan 27, 2011 3:35 pm
concept64
Cat 4
Postby dunlinii » Thu Jan 27, 2011 6:27 pm
Just watched the video. Looks great.
dunlinii
Cat 1
Postby concept64 » Thu Jan 27, 2011 7:13 pm
thanks
This is far from perfect, the sock is not the right carbon diameter which therefore one or two folds (I order the right size and fabric type carbon son) across its should be good after I'll make tests with people outside my circle which will give me an objective opinion and realistic
A beautiful and reliable carbon hubs I paret feasible
I do not know if I have my technical levels the tests I Diron my intuition tell me that my product is my reliable that is not enough
concept64
Cat 4
Postby Boonen » Thu Jan 27, 2011 9:58 pm
Looks great concept64, looking forward to see how this'll turn out! :D
Boonen
Postby concept64 » Sat Feb 05, 2011 6:59 pm
I'm back
the carbon body is finished you can see from this video
rest up after the aluminum rings on which the shelves will be fixed
estimated weight will be 43gr light model will be tested in the second time in 40gr
The first model will be tested by a specialist (wheel craft)
http://www.rouesartisanales.com/
video of the body
http://www.youtube.com/watch?v=2e1JLjRBHiE
video of assembly
http://www.youtube.com/watch?v=7zBVEkmA2fg
concept64
Cat 4
Postby Boonen » Mon Feb 07, 2011 9:58 pm
Very cool, these remind me a bit of the old campa front hubs.
Boonen
Postby Gumgardner » Mon Feb 07, 2011 10:25 pm
Damn...you are talented
Gumgardner
Cat 2
Postby concept64 » Sat Feb 12, 2011 10:27 am
it is finished ...
Here now and the implementation of a front wheel hubs carbon road
For this project, my goal was to make a reliable product and aesthetics.
For the next reliable, I decided to work on the following:
✓ shelving with head right spokes (for a maximum clamping)
✓ The alignment of the head spokes that are in the axis of ball bearings
✓ The positioning of the bearings and the spokes is most eccentric possible (for maximum stiffness)
✓ Mounting hybrid bearings (ceramic balls and steel cage)
✓ Drilling with the passage of spokes pointing in the axis of the assembly, which allows a diameter adjusted, better maintenance of the spokes as well as a contact with the aluminum rings and head spokes.
To validate these technical skills, I asked the company RAR
to test the hubs and I will not fail to publish the report
For the second objective (aesthetics), I'll let you see the video of the hubs
http://www.youtube.com/watch?v=8JQqGyY1zNs
concept64
Cat 4
Postby dunlinii » Sat Feb 12, 2011 6:59 pm
That is one sexy hub. Saw the video this morning when it came up on my Youtube :D
dunlinii
Cat 1
Next
