DIY DI2
Re: DIY DI2
Postby skimons » Mon Jan 24, 2011 2:07 pm
Oilman wrote:Yes it works correctly. I also unplugged the FD when measuring, so I was able to understand the communication between junction box, FD and RD.
same here (RD works without FD), but i used all "original" parts.
any problems to expect when i tie in a battery on the front wiring harnass?
skimons
Cat 4
Re: DIY DI2
Postby manninen » Mon Jan 24, 2011 3:32 pm
this is where the magic happened
4 wires to RD, including those soldered battery cables
4 wires thru original connector to gear switches, 3 on use
all done like in page 1 schematics
doing it wrong?
manninen
Cat 3
Re: DIY DI2
Postby manninen » Tue Jan 25, 2011 9:17 am
is it possible to press up/down shift buttons accidently same time on original Di2 system? at least they are very close together
just thinking i´ve burned front box by pressing both button at same time
it does sound good, but might be possible to press those buttons same time even on original TT switches
depends how they connect
manninen
Cat 3
Re: DIY DI2
Postby manninen » Thu Jan 27, 2011 10:10 pm
could someone measure voltage on original fully charged battery.
my chinese is 7.64v
manninen
Cat 3
Re: DIY DI2
Postby Oilman » Fri Jan 28, 2011 9:21 pm
Should be 8.4 when no load is applied. But at 7.6V the derailleurs should operate fine.
Oilman
Cat 3
Re: DIY DI2
Postby Jeffr » Sat Jan 29, 2011 12:31 am
You can press the buttons at the same time. Electrically it is not a problem.
I can't see the colors and wires well enough to tell if you have a connectivity problem. Up shift and down shift go on the same RD wire. Should be green, I think. White should go to the fd shifter. Blue goes to both.
Jeffr
The Man in Black
Re: DIY DI2
Postby manninen » Sat Jan 29, 2011 7:31 am
thanks, just thinking what i have done wrong. when you press both buttons at same time its kind of shortcircuit.
red, black and green connected together. but i guess shimano made it that way it doesnt matter
ok, 7.6v isn´t overvoltage :)
can someone test which indicates battery conditon. FD and RD plug off and press that switch to indicate
if green light doesn´t lit, plug RD and press again
cause i´m not getting any green or red here
search continues
manninen
Cat 3
Re: DIY DI2
Postby Jeffr » Sat Jan 29, 2011 7:47 am
why would red black and green be connected together if you're pressing both buttons?
Are you using a normal shimano shifter? If not it sounds like you have your buttons wired wrong.
Jeffr
The Man in Black
Re: DIY DI2
Postby manninen » Sat Jan 29, 2011 7:50 am
if theres three wires they´re all connected when pressing them together, one "positive" 2 "negatives"
manninen
Cat 3
Re: DIY DI2
Postby Jeffr » Sat Jan 29, 2011 7:53 am
Are you using your own buttons or di2 levers?
Jeffr
The Man in Black
Re: DIY DI2
Postby Jeffr » Sat Jan 29, 2011 7:55 am
I see, I looked one page back, sorry. Your own. You may simply have them connected improperly. There is one voltage source and three different button wires. You simply connect voltage to any button wire momentarily to trigger it. It doesn't matter if more than one button is connected simultaneously. They're all inputs except for voltage.
Jeffr
The Man in Black
Re: DIY DI2
Postby manninen » Sat Jan 29, 2011 8:00 am
this is how it´s connected
correct me if i´m wrong
connected like pritchet74´s shimagnolos
manninen
Cat 3
Re: DIY DI2
Postby manninen » Tue Feb 01, 2011 12:00 pm
ok, it works!!
somehow i blowed my front cable set/or it didn´t work as new (my best quess is static electricity)
just bought a new one and installed it
-battery condition information comes from FD
-you can press both up/down switches at the same time with out breaking anything
now i have to think about cranks, low Q or high stiffness (old dura-ace or sram rival, i have them both)
manninen
Cat 3
Re: DIY DI2
Postby Mike K. » Tue Feb 01, 2011 12:43 pm
Success! Congrats! Great to see that your determination paid off!!! :applause:
Mike K.
Cat 1
Re: DIY DI2
Postby manninen » Tue Feb 01, 2011 1:37 pm
quite a journey :D
when i started i didn´t know much what i´m getting into but skimons and jeffr helped a lot!
without jeffr i would propably fried that RD :)
this was right forum to get it thru
manninen
Cat 3
PreviousNext
