Without a production of about 500pcs, it sure doesn't make sense to produce them.
Cheers,
Lee
| Guest Announcements |
This board is currently undergoing changes. Registration for new members is currently disabled while some changes take place. If you'd like to register please drop us an email. |
Jeffr wrote:lipo and lion have different discharge characteristics. I don't know which di2 is, I honestly haven't looked very closely at the battery. lipo will only have about a 1v swing from 100% charge to nearly fully discharged. You can probably find a manufacturer's datasheet for the cells in your pack to determine the right thresholds. Obviously shimano has hard coded it for the batteries they use but other batteries within the same family should have the same charge/voltage curve even with greater capacity.
pritchet74 wrote:No idea about the voltage. I haven't checked it at various charge levels, but the battery level light still works when installing a different battery. I honestly can't ever imagine going back to using the standard Shimano battery. Having it hidden in the seat post is the only way to go. I have a reminder in my iPhone to tell me to charge my battery every 2 months.
Oilman wrote:I've measured the borders battery charge indicator last year:
>7.6V: Green led 2s (100% according to Shimano)
≤7.5V: Greens led flashes 5x (50% according to Shimano)
≤7.0V: Red led 2s (25% ...)
≤6.0V: Red led flashes (0%)
The front derailleur stops working when the voltage comes below 6.8V. The rear-derailleur works fine when the voltage is above 6.2V, when it drops below 6.2V you can get it shift but it isn't shifting smoothly anymore.
When the graphs posted by Jeffr are also valid for your Lipo battery you should charge the battery when the green leds start flashing. When you'll wait till the red led comes on, you're too late.
ToddC wrote:pritchet74 wrote:No idea about the voltage. I haven't checked it at various charge levels, but the battery level light still works when installing a different battery. I honestly can't ever imagine going back to using the standard Shimano battery. Having it hidden in the seat post is the only way to go. I have a reminder in my iPhone to tell me to charge my battery every 2 months.
Thanks for the reply. I haven't decided if I want to go in the post or in the seat tube, down tube, etc... If you are using a Lipoly knowing the voltage is paramount. Just found your post with the new battery set up. You didn't mention balancing these cells in your post. Before soldering these cells together all of the voltages should be pulled together within a few hundredths of a volt. After assembly a balancer should be used at least on the first charge cycle.
pritchet74 wrote:Wow. I am shocked you got them warrantied. And also shocked that you fried them parts.
nathasm wrote:pritchet74 wrote:Wow. I am shocked you got them warrantied. And also shocked that you fried them parts.
I know I'm lucky, that's why I'm hesitant to try again.
But if what I wrote sounds correct and the battery choice is correct, then I'll probably give it another go.
Users browsing this forum: Google [Bot] and 1 guest
