Berk INTEGRATED seatpost&seat 112.3g
Postby ... » Sun Nov 07, 2010 8:20 pm
Berk integrated seatpost&seat
Weight: 112.3g
Length: 270mm
Diameter: 31.6mm
For "73 degree" frames.
On the bike:
The shape of the seat is alsmost the same as Selle Italia c64, I only made it 5mm shorter.
The tube has UD-finish.
I already tested it for one ride and everything went perfect - will write more about the product as soon as I manage to test it for a bit longer time..
Hope you like it!
Cat 1
Re: Berk INTEGRATED seatpost&seat 112.3g
Postby Gumgardner » Sun Nov 07, 2010 8:54 pm
We like it, but we also want it. Quit teasing us!
Gumgardner
Cat 2
Postby pritchet74 » Sun Nov 07, 2010 10:35 pm
Wow. Nice!
pritchet74
Aerodymatic Man
Postby Boonen » Sun Nov 07, 2010 10:46 pm
Yep, that's very cool, nice job! :D
Boonen
Faster than Superman
Postby ... » Sun Nov 07, 2010 10:51 pm
Thanks!! :D
Cat 1
Postby Gumgardner » Mon Nov 08, 2010 12:40 am
Without rails, is there a lot of 'bend' at the edges, since there isn't any support from the rails?
Gumgardner
Cat 2
Postby rlpaul » Mon Nov 08, 2010 2:40 am
That is really cool. I ride a c64 regularly, and am curious how it compares :)
rlpaul
Cat 2
Postby FAQinc » Mon Nov 08, 2010 3:16 am
Is the yellow outline patch at the back of the saddle there for reinforcement or flex as it looks a bit kevlarish?
Also can you somehow measure nose or back end deflection compared to a standard saddle very currious?
Amazing work man thats lighter than a lot of stock saddles keep it up!
FAQinc
Cat 2
Postby BMANX » Mon Nov 08, 2010 6:29 am
That is a damn sexy saddle. That would make me switch over to a carbon saddle.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98lbs
BMANX
Cat 1
Postby ... » Mon Nov 08, 2010 2:59 pm
Thanks!!
About the back of the saddle - there is a kevlar-carbon reinfocement. Here just one more photo (just glued):
The nose of the saddle is really very stiff. The back of the saddle is quite flexible (left and right "wing") but it's not disturbing.. Will write more soon!
Cat 1
Postby ... » Mon Nov 08, 2010 9:04 pm
I just made 2.2h on my roller and everything went perfect - it's almost the same as sitting on the serial Selle Italia seat, the only difference is that it's probably just a little bit harder on the centre, but you just "fall" into the seat. I just love it! :grin:
I'll try to make some carbon fibre saddle rails for a normal seat - probably I could make the base of the seat a bit lighter (for more comfort) because the seat should be stiffer with the saddle rails. Will see :wink:
Cat 1
Postby Ypsylon » Mon Nov 08, 2010 9:11 pm
Very nicely done.
Maybe if you used a single but wider "rail" you'd get some flex and comfort?
Ypsylon
Herr Pfennig
Postby drPhilGandini » Mon Nov 08, 2010 9:51 pm
Nice weight, but surely a saddle should flex in the middle and not the edges. This is the design goal of having rails that connect at the front and the rear so that the saddle is suspended in between, and flexes. This design looks to be antithetical to that principle.
dr Phil Gandini
2010 Neo Ultimate
drPhilGandini
Cat 3
Postby ... » Mon Nov 08, 2010 10:04 pm
drPhilGandini wrote:Nice weight, but surely a saddle should flex in the middle and not the edges. This is the design goal of having rails that connect at the front and the rear so that the saddle is suspended in between, and flexes. This design looks to be antithetical to that principle.
You're right, but for the first product of that type I'm quite happy. It would be for sure better to make it like you describe it. But first I'll try to make ordinary saddle rails, and then I'll probably start with a new mould for the seat tube :wink:
And I prefer saddles with a hole on the centre... :mrgreen:
Cat 1
Postby dunlinii » Mon Nov 08, 2010 11:54 pm
I feel a hole in the centre comming :grin:
Serioulsy cool.
dunlinii
Cat 1
Next
