Site Announcements
fairwheelbikes.com/c/topics
magura MT-8 brake squeal
Postby spookyload » Sat Nov 03, 2012 2:31 am
I have been running a set for three months now and it just won't go away. Anyone else having issues with the MT-8s? I have tried cleaning everything, retensioned the rotor bolts, and tried bedding them in as much as possible. Still a squeal with more than 50% lever pull.
spookyload
Cat 5
Re: magura MT-8 brake squeal
Postby Ypsylon » Sat Nov 10, 2012 9:00 am
Both front and rear? Did those come with the bike or did you ever use other brakes on the bike?
Ypsylon
Herr Pfennig
Postby Juanmoretime » Sat Nov 10, 2012 11:24 am
Are they 160mm. My friend has them in 160 and they are completely silent. Could you have some contamination on the rotor or maybe some air in the line requiring a bleed? Have you tried to either sand the pads or use different ones? Could not be any of those but they are things to check.
Juanmoretime
Cat 1
Postby Fibre-Lyte » Sat Nov 17, 2012 6:31 pm
Swap the pads for a different/better brand. I've known a few people have squealing brakes and a simple pad swap rectified the problem. Other than that, if the rotors are getting very hot you might have the same problem.
Fibre-Lyte
Manufacturer
Postby spookyload » Sun Dec 16, 2012 10:21 pm
Thanks for the tips. I will likely swap the pads out when I get to Tucson next month and my bikes arrive from Germany.
spookyload
Cat 5
