Campy lever angle adjustments?
Postby wkochi » Fri Oct 12, 2012 3:31 pm
Is there a way to angle the brake lever to angle outward like the recent posted Sugarkane's front picture?
link to picture....
http://fairwheelbikes.com/cycling-blog/ ... _small.jpg
my Campy SR11 levers are perpendicular to the ground (straight up and down) while Sugarkane's is angled outwards like my DA7900 levers.
I would rather match the DA7900 levers because i'm so used to the angle. feels odd that the Campy levers can't be adjusted to match....unless i'm missing something.
thx.
wkochi
Cyclotourist
Re: Campy lever angle adjustments?
Postby Ypsylon » Fri Oct 12, 2012 7:08 pm
AFAIK you can't angle the levers by themselves, but I could be wrong,
There are various handlebars that flare out from the tops to the drops that might do what you are looking for.
Ypsylon
Herr Pfennig
Postby wkochi » Fri Oct 12, 2012 8:56 pm
i wonder how Sugarkane angled his out. that's at least a 12% angle from perpendicular.
wkochi
Cyclotourist
Postby Ypsylon » Wed Oct 24, 2012 2:59 pm
Not sure what bars those are, but they should do the trick.
Ypsylon
Herr Pfennig
Postby Fibre-Lyte » Wed Oct 24, 2012 8:18 pm
@wkochi, it's just as Ypsylon says about the bars plus the point at which the photo has been taken gives a perspective that makes it look as though the lever blades angle out from the hoods when in fact I think that they will be in line like yours.
Fibre-Lyte
Manufacturer
Postby pritchet74 » Thu Oct 25, 2012 5:51 am
Ypsylon wrote:Not sure what bars those are, but they should do the trick.
That's just frightening.
pritchet74
Aerodymatic Man
Postby l33boy » Fri Oct 26, 2012 9:04 am
Although the above is just obsurd.... :shock:
In response to the OP, yes you can easily angle the shifters like that.
Loosen the bolt a little and just move them around the curve, you'll see that you can achieve that angle quite easily.
TTFN
Bike
9.2Kgs ----------------------------I 6.5Kgs :)
Me:
92Kgs ------------------------I----- 84Kgs :(
l33boy
Cat 5
Postby wkochi » Sat Oct 27, 2012 8:56 pm
l33boy wrote:Although the above is just obsurd.... :shock:
TTFN
thx. i loosen up the clamps...wiggled them around a bit. not much leeway, and not even 1degree difference. must be the bars.
wkochi
Cyclotourist
Postby l33boy » Sat Oct 27, 2012 9:05 pm
really? not even if you turn them in a bit? turn them in and the shifters fare out.
thats why they have fitting instructions, so that you set them as the manufacturer wants.
I had a go on my new build and easily got about 5>10 degrees.
Bike
Me:
l33boy
Cat 5
Postby ksroadie » Tue Oct 30, 2012 8:43 am
Check out ITM bars. Out of business, but can still fine 'em online. I really like their carbon traditional bend "101 Strada" (stiff and light), but it flares just a little too much for my taste with Campy 11 speed shifters. Might be what you're after.
Every time I see an adult on a bicycle, I no longer despair for the future of the human race. —H. G. Wells
ksroadie
Cat 3
Postby sugarkane » Wed Nov 21, 2012 12:59 pm
the bars are 3t ergonovas and you should be able to angle the levers as you like... its not a depth of field thing either with the photo i do run them angled like that..
it might be hard to do with the bars all taped and cabled up.
there is a molding seam along the top of the rubber hoods.. i run this straight back parallel with the bars... this cants the tops of the hoods in a bit and the lever blades out..
next time you have the tape off the bars give it a swing, should be pretty easy
sugarkane
Cyclotourist
cron
