by sybarite » Fri May 27, 2011 2:29 am
Bars are 3T Bio Morphes, have looked for flat topped, compact bars around but this still works for me. I've tried every bar stem combo (Deda, Zipp, Schmolke, FSA, PRO, Talon, waiting for new Vuka Sprint, and even a NORA combo), this still ended up being a personal preference.
Same with the wheels, the RZRs are the best handling and stiffness I've tried so far - very different from the Lews or even 20 spoked LW fronts. My other favourite wheel is a set of 25mm Enve tubulars laced with Extralite hubs - surpringly stiff and climbs well. The older Lew that another riding buddy had ended up with an endlessly squeaking rear hub after 3 weeks - hope that doesn't happen here. Mavic Ultimates are a close second. MVs and Ventoux are too soft for me, and I will get to try a set of Madfiber loaners to test next week.....
The rear cage setup is a half Berner 15T - communication with Berner was tough - so I ended up buying a pulley through someone in Europe instead of having it fitted, etc. Shifts alright with Di2 afaik.
The crank and chainrings came together - 7900 specific rings built for the 7900C crank. I still refer my 175 cranks, have a nice Rotor 3D+ that cannot fit BB86 frames (the thinner bearing retrofit disintegrates - dont ask how I know), and 3D cranks are still 'in production'......maybe EEs will beat them? Nothing quite like stiff cranks, shoes, and a smooth BB to feel the effects of better 'power transmission'....and I'm sure there must be a pedal equation in there somewhere...
