cable ajuster
cable ajuster
Postby quick_step » Fri Mar 25, 2011 3:59 am
I need to ask you guys a question ,I just picked up a new frame it is basicly the torelli carbon frame with the over sized head tube 1 1/8 by 1.5
ok what im asking is the cable guide goes through the head tube is there a barel ajuster that works with campy ? any ideas ? thanks :? :)
Put some fun betwen yer legs
quick_step
Cat 3
Re: cable ajuster
Postby Ypsylon » Fri Mar 25, 2011 8:19 am
You mean the housing goes all the way through the headtube and the cable stop on the downtube won't accept a barrel adjuster?
Like this?
My first idea is that you can always use an in-line barrel adjuster anywhere you like, usually close to the ergo powers.
You can get away without a barrel adjuster at all, too. The RD has one anyway and the FD needs a little more patience to adjust, but it's not too difficult.
Ypsylon
Herr Pfennig
Re: cable ajuster
Postby quick_step » Sat Mar 26, 2011 12:51 am
Yes the same frame but badged with a diferent name , gota love all of indavidual R&D claims, but at cost its worth it. I will take your advise though I would like to get a set of in line cable ajusters :)
quick_step
Cat 3
Re: cable ajuster
Postby Ypsylon » Sat Mar 26, 2011 7:37 am
Which part of my advice are you refering to, that you could use an in-line adjuster or that you can live without? :confused:
Maybe a pic helps
how they work
Ypsylon
Herr Pfennig
Re: cable ajuster
Postby quick_step » Tue Mar 29, 2011 1:38 am
I would go with the inline cable ajusters as campy needs attention now and again ,Thanks for the picks Ypsylon ! :D
quick_step
Cat 3
