1991 Cannondale 3.0 (13.6lbs)
Postby VintageWW » Mon Mar 21, 2011 3:16 am
So I thought it was time to finnish last year's winter project. I wanted to find a vintage frame that was stiff for climbing but was not in any way expensive. I found this almost NOS full stock original Cannondale 3.0 on ebay from first owner. After a small bid war I got it for just $530. At first I dint know what to do with it because it clearly hung out in storage for 19 years and the original shimano 600 and cinelli parts......spotless! Well I eventually decided to go with my budget weight weenie plan and put all the sweet parts on another bike and started the madness!
Frame--------------1991 3.0 Aluminum 56cm 1455gr
Fork---------------- Easton EC90SL 1inch (Tuned plug and cap)
Headset------------ Chris King nothreadset 1
Stem---------------- Alpha Q prolite 120 TI bolts 118gr
Handlebar----------- Zipp SL 42
Crankset------------ Kcnc K-type RD2 Compact with scandium bottom bracket 652gr
Pedals--------------- Xpedo Thrust mag/Ti 196gr
Seat Post------------ Kcnc ti proe lite (cut with carbon bottom clamp) 117gr
Saddle--------------- full carbon Meark (sanded off lacquer)
Brake Levers-------- Modolo (tuned) 210gr
Shift Levers---------- Dura-Ace 7900 SIS (cut)
Brakes----------------- Origin8 Pro Force Torq-Lite II 204gr
Cables/House--------- Jagwire/Alligator Ilink
Rear Derailleur-------- Dura-Ace 7900 (Tuned with hand drill and Ti parts) 148gr
Front Derailleur------- Dura-Ace 7900 (Tuned with hand drill) 52gr
Chain------------------- YBN 220gr (will be getting a KMC)
Cassette---------------- Recon 11-25 98gr
Tires-------------------- Tufo S3 pro 390gr
Wheels----------------- Velomax hubs KOM rims 1130gr
Skewers---------------- Titanium bolts 42gr
Rim Tape-------------- Tufo ex
Bar Tape--------------- cotton
Bottle Cage------------ carbon (drilled/nylon bolts)
VintageWW
Cat 5
Re: 1991 Cannondale 3.0 (13.6lbs)
Postby sjubbis » Mon Mar 21, 2011 8:37 am
Beautiful bike buddy! :)
sjubbis
Cat 4
Postby Ypsylon » Mon Mar 21, 2011 8:52 am
Very respectable weight for a non ww-frame. I really like the combo of current parts and some that are a bit older and how you carried the theme throughout the enitre build.
Ypsylon
Herr Pfennig
Postby mdeth1313 » Mon Mar 21, 2011 5:26 pm
Nice- I have an early 90's cannondale criterium series frame but the rear spacing only allows for a 6 speed cassette- or so I thought- anyone else have any idea about this?
mdeth1313
Cat 1
Postby VintageWW » Mon Mar 21, 2011 6:39 pm
The only way to really tell is to spread her legs and give it a try. the spacing on this bike is 128 because cannondale knew that 8 speed was on the horizon so they wanted to open up the back end a bit on the higher end mobiles to allow for upgrades although at the time 126 was the spacing for most of there 6-7 speed bikes. Going from 128 to 130 was a matter of 2mm but if its 126 that might be a stretch.
VintageWW
Cat 5
Postby dunlinii » Tue Mar 22, 2011 10:51 pm
I think that looks great, although I wouldn't have gone for the bright housing myself, but hey :wink:
dunlinii
Cat 1
Postby Boonen » Wed Mar 23, 2011 6:39 pm
Great bike VintageWW!! Oozes character, really like how you tuned most of the parts and put some of the 'old classics' in there with the newer parts, very nice :D How does it ride? Those were great frames in their day and I think they would still stack up well against lots of modern offers.
Mdeth, I'd just give it a try, or maybe it would be a nice base for a single speed or a fixed gear bike? :D
I've had mtb hubs (135 mm) in a road spaced (130) cx frame and other then having to fiddle a bit to get it in it seemed to work fine.
Boonen
Faster than Superman
Postby skimons » Mon Mar 28, 2011 9:38 pm
great mix of various parts, very nice. good job!
wonder how those stubby's shift :D
skimons
Cat 4
Postby JLFast » Sun Sep 02, 2012 7:24 pm
Sorry to resurrect an older thread, but this is really impressive. Ive been watching 'same era' Cannondales on ebay lately with this in mind. Amazing how so many are mint with all original parts, yet others are thrashed. As it should be I supposed!
My 2011 Winter project was a 1983 Benotto, period correct, but now Im looking at it as a tank that needs about 4 lbs taken out.
Current project is a 2003 Pinarello Prince, and its getting there; but your build has given me a few ideas to take it further.
Well done!
JLFast
Cyclotourist
