38t 130bcd rings
38t 130bcd rings
Postby Jeffr » Sat Dec 25, 2010 8:58 am
Hey folks. Does anyone have experience with 38 tooth 130 bcd chainrings? Any complications? Any recommendations? I live in a very hilly area and don't really like my compact that much. It'd give me the equivalent of the next larger gear in the rear.
Jeffr
The Man in Black
Re: 38t 130bcd rings
Postby rlpaul » Sat Dec 25, 2010 6:05 pm
The only negative I can think of off the top of my head is slightly slower shifting in front due to the larger jump. Whether that's noticeable or not though.... /shrugs. I've opted to do the opposite, 36t on the compact.
I don't think there will be any real issues, but haven't seen anybody go smaller on a standard double around here. Of course, its pretty flat here too :)
rlpaul
Cat 2
Postby Matteo » Sun Dec 26, 2010 5:08 am
I am using a 38t Specialite TA Hegoa in combination with a 50t big ring and it works just fine. With 50-38 the jump between the rings is actually less then the standard 53-39, and I am not fast enough to need a 53.
Matteo
Cat 3
Postby maxxevv » Sun Dec 26, 2010 6:07 am
Jeff,
I tried that some time ago. Didn't work very well as it was a little noisy on my preferred cranks.
If you already have a compact, and if don't need a 53, then a compromise and better working system would be a 50/36 or a Compact 52/38.
A 52/36 works well too as I'm using that at the moment. This is because of the Di2 compatibility issues with a 50T on a brazed-on frame mount.
maxxevv
Cat 1
Postby darnellrm » Tue Dec 28, 2010 1:44 am
I have been running a 50/38 combo on standard cranks for 10 years and it works great. Anything smaller than 38t seems to give too low gears to be useful on my routes and I can't push anything bigger than a 50-11 anyway.
darnellrm
Cyclotourist
Postby pritchet74 » Tue Dec 28, 2010 4:11 am
Jeff - I am using a 52t/38t setup on my standard cranks & it's great. No problems at all and shifting is excellent. I have been using my Fibre-Lyte carbon rings and I have a nearly new FSA 38t chainring that you have if you want it.
pritchet74
Aerodymatic Man
Postby Boonen » Tue Dec 28, 2010 10:32 am
It should work fine but it depends a little on your cranks, on some the sides of the chain hit the tips of the spider which makes for noisier and less then optimal setup.
Boonen
Faster than Superman
Postby Fibre-Lyte » Tue Dec 28, 2010 12:10 pm
That's a good point. If I remember rightly the Storck Power arms (older version certainly) and the Claviculas recommend against using a 38t because the chain can damage the spider. I think in most cases that only applies to carbon cranksets as alloy ones have less material around the bolt hole but it's worth checking.
Fibre-Lyte
Manufacturer
Postby abb7 » Thu Jan 27, 2011 6:33 am
pritchet74 wrote:Jeff - I am using a 52t/38t setup on my standard cranks & it's great. No problems at all and shifting is excellent. I have been using my Fibre-Lyte carbon rings and I have a nearly new FSA 38t chainring that you have if you want it.
Hmm, I just posted up about Stronglight CT2 rings and there's a bit of crossover here. What brand of cranks? I understand them to be 130BCD? Did you run your aluminum FSA chainrings 52-38 too, before going to the carbon rings?
Thanks so much. I want to run aluminum 52-38 on my EC-90 crank.
abb7
Cyclotourist
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
