Scott Addict SL 11.5-11.6 lbs (the CR1 is no more)
Re: Scott Addict SL 11.5-11.6 lbs (UPDATE March 12)
Postby mdeth1313 » Sat Mar 12, 2011 11:53 pm
Well- after a retul fitting, I found out I should be on a size small frame and not a medium. As I simply cannot justify another frame purchase right now, we worked on getting me into an optimal position for this frame, which meant-
lose the xx-light seatpost for a setback post
lose the schmolke bars for ones with a shorter reach/drop
lose the 100mm stem for a 90mm stem
Fortunately the 3 above things sold relatively quickly and for more than my replacements ended up costing me (save the stem).
I also switched from lightning cranks to zipps which dropped about 20g.
Replacements:
pro-vibe carbon setback post 31.6x280 152g (xx-light was 91g)
ritchey superlogic II carbon bars 183g (schmolkes were 159g)
extralite oc stem (same weight)
So, I ended up gaining 85g (at least that'll be the net when I get the extralite stem) - the 20g for a 65g gain. Of course, I now need to shorten my cables and housing- the shorter reach and narrower bars require less housing so that'll knock back a few more grams. If I used an alloy cassette I could probably get it back under 11.5lbs- at the lowest I had it at 11.33lbs.
I will be switching to a sram cassette once the 7900 cassette wears out, which will probably drop another 15-20g.
On the upside-- the difference in my position is just unbelieveable- I'll never go to a new frame/bike w/out getting fit.
Now if I could just sell the brand new schmolke tlo bars I have laying around :roll:
mdeth1313
Cat 1
Re: Scott Addict SL 11.5-11.6 lbs (the CR1 is no more)
Postby pritchet74 » Sun Mar 13, 2011 2:50 am
Pics, or it didn't happen. :wink:
pritchet74
Aerodymatic Man
Postby mdeth1313 » Sun Mar 13, 2011 1:09 pm
pritchet74 wrote:Pics, or it didn't happen. :wink:
yeah- need to finish it off- moving your bars/shifters back by stem length/reach creats a lot of extra cables sticking out. Need to finish it off! Besides, who wants to put a pic up w/ a FSA stem on there? :oops:
mdeth1313
Cat 1
Postby Soloist Assassin » Mon Mar 14, 2011 12:50 pm
Eric go with a Red cassette. They are a bit loud, but my 11-23 Red cass, is 55g lighter than my 11-23 Force cassette. That makes up most of your difference, and the loud thing isn't that big of a deal.
Soloist Assassin
Cat 2
Postby mdeth1313 » Mon Mar 14, 2011 4:48 pm
Soloist Assassin wrote:Eric go with a Red cassette. They are a bit loud, but my 11-23 Red cass, is 55g lighter than my 11-23 Force cassette. That makes up most of your difference, and the loud thing isn't that big of a deal.
Already have it (Red).
On another note- I rode 60 miles yesterday (temps in the mid-40's). The fitting was worth every freaking penny-- usually within a couple of hours of finishing a ride my quads hurt like hell walking downstairs- no pain- NONE. When I woke up this morning I had no pain nor soreness. Let's hope this becomes the norm!
NOW SOMEONE BUY MY FREAKING SCHMOLKE BARS!
mdeth1313
Cat 1
Postby mdeth1313 » Mon Mar 28, 2011 10:39 pm
So, I got around to installing an extralite OC stem- I was using a FSA 115 stem until it arrived- nice go to from 148g to 81g. I put the bike on the scale- keep in mind I haven't shortened my i-links nor replaced the rear brake cable with a powercord (the front is still a PC, I just ran out last time I switched things around- I have them now). I'm also still using the 7900 cassette instead of a sram red.
I threw it on the scale just for kicks - 11.64lbs. If I went w/ an alloy cassette I'd have it under 11.5 again. (I Know, I need pics- yeah, when I finish everything up) BTW- that's 11.64 w/ the garmin 500 and speed/cadence sensor on there!
mdeth1313
Cat 1
Postby imola » Tue Mar 29, 2011 3:18 pm
Hi quick question, I am looking at one of these frames, what is your seat top to BB in cm, please?
Mines 73.0 and I think I need a medium. With my measurements on a M/54 frame I'd need a 110mm stem which is OK. And with a setback post. This might make the 52cm an issue as on the S/52, the seat tube angle is pretty steep.
Anyway, would be helpful to know your seat top to BB centre please. Nothing looks worse than insufficient seatpost extension.....
imola
Cyclotourist
Postby pritchet74 » Tue Mar 29, 2011 5:25 pm
mdeth1313 wrote:So, I got around to installing an extralite OC stem- I was using a FSA 115 stem until it arrived- nice go to from 148g to 81g. I put the bike on the scale- keep in mind I haven't shortened my i-links nor replaced the rear brake cable with a powercord (the front is still a PC, I just ran out last time I switched things around- I have them now). I'm also still using the 7900 cassette instead of a sram red.
I hate you.
:xBanana6:
pritchet74
Aerodymatic Man
Postby mdeth1313 » Tue Mar 29, 2011 9:25 pm
imola wrote:Hi quick question, I am looking at one of these frames, what is your seat top to BB in cm, please?
Looks to be a bit more than 71cm. If you're looking for perpendicular (instead of following the seat tube, it looks to be around 70cm, but I'd have to take a more accurate measurement.
mdeth1313
Cat 1
Postby imola » Tue Mar 29, 2011 9:30 pm
Thanks - is that measuring a line from the centre of the BB up a line through the centre of the seat tube to the seat top........ I think thats what you meant, but I'm feeling a bit thick as I have the flu.
imola
Cyclotourist
Postby Soloist Assassin » Fri Apr 15, 2011 3:10 am
I see you have your frame for sale now. What are you up to now?
Soloist Assassin
Cat 2
Postby mdeth1313 » Fri Apr 15, 2011 9:25 am
Soloist Assassin wrote:I see you have your frame for sale now. What are you up to now?
I'm not. It was a serious consideration after selling the other set of schmolke bars (and breaking even). After a long ride on the addict, I decided I'm enjoying the new setup so much going to a different frame was not worth it.
I did just pick up exustar 200 ti pedals which are about 8g lighter than the iclics, the cleats are also about 10-15g lighter and they look ALOT better on the bike than the iclics!
mdeth1313
Cat 1
Postby mdeth1313 » Tue May 03, 2011 9:23 pm
So, exustar pedals dropped a few grams (as in under 10), but it looks as if fiber-lyte rings are in store for my vumaquad (birthday rapidly approaches). School ends June 24th. Thereafter should start the pics and weights!
mdeth1313
Cat 1
Previous
