Site Announcements
fairwheelbikes.com/c/topics
My rebuild - "DANICA" 5980g / 13.18 lbs. Cervelo SLC
Re: My rebuild - "DANICA" 5890g - 12.98 lbs. Cervelo SLC
Postby BMANX » Thu Sep 02, 2010 7:36 pm
Should have some new goodies today for my baby.
After 3 hours and 90km on her today I have decided to name her "DANICA" my Raven Haired Rocket.
It was amazing and I think that she will get a bit more muscle in the next few weeks which should make her just a bit heavier but faster.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98lbs
BMANX
Cat 1
Postby pritchet74 » Thu Sep 02, 2010 10:08 pm
So, Danica, eh?
I love it! We gotta get Danica and Victoria together for some drinks some time. Now THAT will be a party!!!
:party:
pritchet74
Aerodymatic Man
Postby BMANX » Thu Sep 02, 2010 10:28 pm
Just like my favorite female racer. Light, fast and dead sexy. Long before I ever had kids and Danica Patrick came along I loved the name Danica. So when my daughter was born I got Danica veto'd right out the window in about 2 seconds. So I guess I can use it now.
BIG DADDY B FLOW
BMANX
Cat 1
Postby williamsf1 » Fri Sep 03, 2010 10:02 am
quick question again....
I got the Zipp vuma cranks today and they are lovely!!!!
its a BB30 ceramic BB?
and going on a cervelo S2....
this is right eh?
williamsf1
Cat 3
Postby williamsf1 » Sun Sep 05, 2010 5:12 pm
to answer my own Q english BB!!!
I got confused with the whole BB30 written on the inside of the crank arm!!!
williamsf1
Cat 3
Postby BMANX » Mon Sep 13, 2010 1:45 am
Danica has been amazing to ride over the last little while but as mentioned, she will get a bit more muscle and with muscle you get a bit more weight.
She now has some full aero rings and a heavier crank as per the previously pictured when she was red and she will be getting some Sram Force levers and RD. Other changes will be Zero Gravity brakes, Fizik saddle and maybe some aerobars. She will be a lean mean aero machine. Just need to source some very nice aero brakes.
BIG DADDY B FLOW
BMANX
Cat 1
Postby Soloist Assassin » Mon Sep 13, 2010 1:59 am
Why the brake change, didn't like the KCNC? Going to Simkins? Why going to Force now? Thanks for linking me to this BTW. You have lots of ideas I can employ on my own SLC.
Soloist Assassin
Cat 2
Postby BMANX » Mon Sep 13, 2010 5:09 am
I have been changing all my bikes around in the last 3 months so much that I could not really keep my focus on the builds but have finally sat down to sort them out. The SLC will become an aero road bike with as much light weight aero parts as possible. I had simkin's and Tektro T726R brakes for the build but needed the cash for my latest build. I have KCNC brakes on my third build which is where they will stay and I think the Zero Gravity will go on the SLC.
The EE brakes will work a lot better with the English build especially in the back where the housing exits directly build the seat tube. It will make a super clean set up.
The Sram Red will go on my new English road build as this will be my main build with the nicest components that I will have. The SLC will get 2010 Force and aerobars for a couple of triathlons that I will try to do next year. Aerobars will go on and off as needed. I think the Force will match up with the build nicely.
So the last piece of the puzzle will be some killer aero brakes like maybe some Hooker's if I can ever find them or maybe something modified to work nicely. It will still be nice and light for racing and some fast riding.
BIG DADDY B FLOW
BMANX
Cat 1
Postby pritchet74 » Mon Sep 13, 2010 6:06 pm
Hey, have you seen the new aero road bars that Zipp showed at Eurobike? The top flats are just like an aero base bar. I thing Victoria wants those.
It would eliminate the tops as a hand position (possibly), but even on steep climbs I am usually on the hoods anyways.
Pricey though, but only 220g if I remember correctly, so the weight is good.
pritchet74
Aerodymatic Man
Postby Soloist Assassin » Mon Sep 13, 2010 7:49 pm
pritchet74 wrote:Hey, have you seen the new aero road bars that Zipp showed at Eurobike? The top flats are just like an aero base bar. I thing Victoria wants those.
That's too weird I was going to tell him the same thing. The weight killed it for me though. My bars as like 40g less than that irc. They are the Vuka Sprint bars. I really like them, but I wished the weight was less. http://zipp.com/bars/vukasprint
Soloist Assassin
Cat 2
Postby BMANX » Mon Sep 13, 2010 8:43 pm
I am thinking about something like that in the future and will take the weight penalty but at the same time I need some bars that will allow clip ons as well. The Easton EC90 Equipe do allow for clip ons and they are under 190g so I will most likely stick with them. The do not accept Profile bars however but since I have been using the HED clip-lites for years, it is not an issue. I checked with Easton a long time ago and they said under the table that the HED aerobars were fine to use since the clamping mechanism is way better than Profile's.
BIG DADDY B FLOW
BMANX
Cat 1
Postby BMANX » Mon Sep 13, 2010 8:45 pm
I think the best option at this time is the OVAL aero drop bar with the front clamping support with the under bar aerobar clamps. You can run the aerobar extentions without any armrests as the top of the bars is just as wide as any armrests. It is a half solution at best as you can not angle the extensions the way you want and are stuck with the angle you get.
BIG DADDY B FLOW
BMANX
Cat 1
Postby williamsf1 » Mon Sep 20, 2010 8:37 am
when you got your fibre-lyte rings, what bolts did you use?
as I am thinking of going this way with my newly purchased zipp vuma quads...
also going to have to sand them back I think as they are second hand with a few scratches here and there.....
williamsf1
Cat 3
Postby Ypsylon » Fri Sep 24, 2010 7:13 am
BMANX wrote: It is a half solution at best as you can not angle the extensions the way you want and are stuck with the angle you get.
Which is obviously true, but also the case for a lot of "regular" aero bars. Who would just tilt up the airfoil base bar?
You can get a lot of different extensions and should at least get very close to what you want.
Ypsylon
Herr Pfennig
Postby williamsf1 » Fri Oct 01, 2010 3:57 pm
so what chain ring bolts did you use?
williamsf1
Cat 3
PreviousNext
cron
