Hello all,
We've received (finally!) some ORC hubs from the kind folks at Alchemy Wheelworks. These are pre production hubs, hopefully that last run of useable prototypes before Alchemy moves into regular production. They're only releasing a handful of these, and Fairwheel's supposedly got the only few that aren't presold or slated for wheelbuilds. For the masses still waiting on the ORC, Alchemy now has a projected release of mid to late January. Though given the long delays associated with this hub's release, no one's making any promises at this point. The good news, though, is that Alchemy should have both ELF and ORC hubs available in black, silver.... and red. Also, Jeremy at Alchemy has made specific redesigns to ensure compatibility with Campy 11 speed cassettes without compromising the hub's original design.
After pulling the hubs out of their box, first thing I noticed is how effortlessly the axle spins. In terms of initial bearing drag, probably the best rear hub I've ever felt. I'd attribute that to the larger bearing sizes and excellent machining tolerances. From my hand, the hub went straight to the scale. 222 grams – quite a bit more than the 205 grams originally projected, but a few less than the claimed 225. We knew this was coming, and suspect that most of the weight gain has to do with the removal of the ceramic bearing spec. Alchemy is also no longer using ceramics in the ELF hub. This decision was made partly to keep with the original planned MSRP of $420. Ceramic upgrade will be available for the ORC for an additional $100. Moving on, the next step was pulling the ORC's axle to get a view of the internals. Once the cap was removed, I was able to easily slide the axle out by hand, another testament to Alchemy's careful and accurate machining. The freehub body, however, would not budge. Further disassembly seemed like a bad idea.
Of course Jason would have none of that. On the phone with Jeremy only a few minutes later, he's asking what we need to extract the freehub body and fully disassemble the hub. Jeremy advises against taking the hub apart, then proceeds to explain exactly how to do so. Ten minutes later and twenty five cents poorer, we've got it all apart and photos taken for your viewing pleasure.
So why is the ORC so great? It's light, but not that light. It's not astronomically expensive, but it sure isn't cheap. Well, I see it as a pure performance product. The fact that it's fairly lightweight is more of a bonus. This is a hub that I would personally want to (and will) ride because it might just make my ride more enjoyable. The ORC's hub design is all about stiffness and efficient torque transfer. All the little details that make this hub special contribute in some way to these paired traits. The cassette body is attached directly to the shell with a massive 6807 bearing, and internally attached to the axle with a standard size 6803 bearing. By attaching the freehub to both hub shell and axle, the whole system becomes much stiffer and more structurally sound. Additionally, there's a reinforcement sleeve which essentially increases the axle diameter at the point where it enters the hub shell. The axle itself is relatively large at 17mm, stepped up to 20mm at the center sleeve. Finally, the diameter of the hub barrel is pretty large in diameter, which also helps to increase overall stiffness. Also worth noting is that the freehub mechanism is equipped with three simultaneously engaging steel pawls on a drive ring with 36 engagement points, a few more than most hubs. This should allow for slightly quicker and firmer engagements under pedaling force.
The ORC will be available in both Campagnolo and Shimano versions, and as mentioned, will have no problems with 11 speed cassettes. Changing the freehub body from one to the other is possible, but not very easy. The freehub body and axle end cap will need to be changed, and the wheel will require redishing. The advantage, of course, is having a hub that makes no compromises with flange positions and non drive spoke tension.
For wheelbuilding nerds like myself, here's a writeup from Jeremy at Alchemy regarding the hub's flange dimensions:
The drive side flange is quite large. This reduces stress on the spokes (from pulling force) and increases the efficiency of torque transfer.
Wheel building dimensions are very important to me. Simplistically, flanges spaced further apart create a stiffer and stronger wheel. However, because multi speed drive-trains require sufficient space on the drive side for the gears, and the over locknut dimension (space between the dropouts) is fixed, no modern hub can have symmetrically placed flanges (center right = center left). Thus, the angle from the drive side flange to the center of the rim is smaller than the angle from the non-drive side flange to the center of the rim. This creates what is called "dish". Because of this, the non-drive side spokes must be under a lower tension than the drive side spokes in order for the rim to be centered between the dropouts. This relationship is a simple linear function. Specifically, RBA (right bracing angle) x tension = LBA (left bracing angle) x tension. So, if the RBA = 4 degrees and the LBA = 8 degrees and the drive side tension = 110Kgf, non drive side tension = 55Kgf. While wider flanges produce stiffer and stronger wheels, at some point, the non-drive side tension becomes too low to maintain tension during the low tension cycle that occurs while riding the wheel. So, it is important to balance flange width with non-drive side tension. If you want to increase non-drive (relative) tension you can achieve this by moving the left flange further right (which decreases the LBA) or moving the right flange further right (which increases the RBA). However, moving the left flange further right lowers overall stiffness and strength to achieve higher non-drive side spoke tension. So, you trade a good for a bad. The better way to do it is too move the right flange further right which increases the RBA, the flange width, and the non-drive side spoke tension. All of which add to the strength and performance of the wheel. So, my design has widely spaced flanges and a larger center right dimension, which produces a stiffer and stronger wheel and good non-drive side tension.
Perhaps one of the major downfalls of the ORC is its serviceability. We had a hard enough time getting it apart, and I would wager that most shops' service departments don't have the kind of hub tools we've got. User service is pretty much out of the question. One thing I will add is that I'm optimistic of the ORC's durability, mostly for the quantity (5) and larger size of the bearings used. So I'm guessing it won't need to be serviced that often.
~Richard
