Fantasy Cycling Vuelta a España starting soon.
Check out our new FWB blog Here
09 Zipp 404's
Discussion on road bikes, frames and parts.
09 Zipp 404's
Postby subzero » Mon Dec 08, 2008 1:45 pm
Anyone own or riden the 09 404's? Any feedback or thoughts would be appreciated, thanks.
subzero
Cat 4
Re: 09 Zipp 404's
Postby Adrien » Mon Dec 08, 2008 10:08 pm
Basically the ride is the same as the 08s. The rims, which represent most of the ride characteristic remains unchanged. The hubs are better, they are now butter smooth instead of sandy, and the spoking is mavic alike: radial drive side, and crossed non drive. It helps balancing the stiffnesses of the two sides of the rear wheel.
Adrien
VIP
Re: 09 Zipp 404's
Postby subzero » Tue Dec 09, 2008 12:13 am
Thanks Adrien, so the new spoke configuration has made the rear wheel stiffer in your opinion as I had the '06 404 versions and found the rear wheel far to flexy, hitting the brake pads under load. Also if they haven't changed the rim at all won't they still have the problem of the rims cracking?
subzero
Cat 4
Re: 09 Zipp 404's
Postby pritchet74 » Tue Dec 09, 2008 12:33 am
I think that all rims became the "clydesdale" version for either '07 or '08, so the rims would be stronger than the '06's that you had.
pritchet74
Aerodymatic Man
Re: 09 Zipp 404's
Postby subzero » Tue Dec 09, 2008 6:15 am
pritchet74 wrote:I think that all rims became the "clydesdale" version for either '07 or '08, so the rims would be stronger than the '06's that you had.
I did not know that, did the weight change as well as they were still around the 1250gr mark as I remember, besides the flexing my wheels were fine, I had them in a System Six which felt like a reasonably stiff frame and being between 92-95kgs at the time I might just have been to heavy for them. Thanks for the info "pritchet74".
subzero
Cat 4
Re: 09 Zipp 404's
Postby Giant DK » Tue Dec 09, 2008 8:06 am
As ridden on WW the rims on 404 and 808 has changed!!!
Giant DK
Cat 1
Re: 09 Zipp 404's
Postby subzero » Tue Dec 09, 2008 11:26 am
I read the thread on WW and Waldo says that the rims are wider and a different shape but does not mention anything about being changed to the Clydesdale rim, thou this might have happened as Pritch says in '07/08.
subzero
Cat 4
Re: 09 Zipp 404's
Postby spaniardclimber » Wed Dec 10, 2008 9:47 pm
The 09 404 and 808 get a full toroidal shape, and are a bit wider. Spoke count is 16/20 IIRC.
Hubs have preload adjustment, bigger axle and bearings.
spaniardclimber
Cat 4
Re: 09 Zipp 404's
Postby Starnut » Sat Dec 13, 2008 11:50 pm
The 404 shape changed a lot. It has the brake tracks like th 808/1080 and the 808 recieved a small refinement in shape.
Starnut
"don't pedal harder, pedal faster"
Starnut
Cat 3
Re: 09 Zipp 404's
Postby pritchet74 » Sun Dec 14, 2008 1:15 am
I think that 2009 is the year of "uber-fast" aero wheels. The new Zipp & Hed C2 shapes are the cat's meow. The Hed Stinger tubular wheels shape was tweaked a bit from last year & is supposed to be simply amazing. Zipp's are lighter though. :wink:
pritchet74
Aerodymatic Man
Re: 09 Zipp 404's
Postby alienator » Sun Dec 14, 2008 1:26 am
Either Zipp needs to re-educate it's marketeers or the cycling world needs to find a dictionary:
Toroid: A surface of revolution obtained by rotating a closed plane curve about an axis parallel to the plane which does not intersect the curve. The simplest toroid is the torus. The word is also used to refer to a toroidal polyhedron (Gardner 1975).
Every rim ever made was and is a toroid. If they weren't tires wouldn't mount so well. These are all toroids:
alienator
Resident Trouble-Maker
Re: 09 Zipp 404's
Postby pritchet74 » Sun Dec 14, 2008 2:28 am
That's funny.
pritchet74
Aerodymatic Man
Re: 09 Zipp 404's
Postby Warblade » Mon Dec 15, 2008 12:28 am
I concur! Marketing.....
Warblade
Cat 3
Re: 09 Zipp 404's
Postby WWPantani » Thu Jan 29, 2009 7:24 pm
Surely the point is that they're toroidal in cross section as opposed to in plan?
WWPantani
Cyclotourist
Return to ROAD
