Site Announcements
fairwheelbikes.com/c/topics
Dura ace di2 shifter question.
Postby gogo419 » Sat Apr 20, 2013 3:30 am
Currently have a felt da1 with dura ace di2. I want to throw some road bars on for a road race.. I was just thinking can I just use a set of the climbing shifters? ( the ones designed to be installed near stem?)
And just plug those shifters direct into the junction box without any electric wire mods? Or do they have to be plugged into the normal road shifters?
Cheers gogo
gogo419
Cat 4
Re: Dura ace di2 shifter question.
Postby Ypsylon » Sat Apr 20, 2013 4:10 pm
Is it 7900 or 9000 DA?
Also, I was under the impression, there were no climbing shiftrers for the FD. Did that change?
Ypsylon
Herr Pfennig
Postby gogo419 » Sat Apr 20, 2013 7:04 pm
7900... Ohh. I assumed you could use the shifter for front or rear?
Gogo
gogo419
Cat 4
Postby Ypsylon » Sun Apr 21, 2013 6:36 am
With 7900 I'd believe that as well, as you just need buttons to close a circuit and they'd never know if they are fd or rd. With 9000 and the canbus I wouldn't be all that sure.
Same is true for connecting the shifters directly to the junction Box. I've never seen it, but in theory, that should work.
Ypsylon
Herr Pfennig
Postby pritchet74 » Sun Apr 21, 2013 8:17 pm
Yes, you can do that.
pritchet74
Aerodymatic Man
Postby gogo419 » Sat Apr 27, 2013 5:49 pm
pritchet74 wrote:Yes, you can do that.
Pritchet74. I am hoping your response is to my question about being able to directly plug it into the. Junction box.. Would it require soldering? Or plug and play?
I really need to pull all the cables out of the internals of the base bar and look at what I have to plug into..
Cheers gogo
gogo419
Cat 4
Users browsing this forum: Exabot [Bot], Google [Bot], MSNbot Media and 6 guests
