Done: Wilier Cento Uno, 6.01 kg, new pics post #13
Postby Fourthbook » Mon Nov 07, 2011 10:30 pm
Made some updates to my ride including a set of Enve 3.4s w/Tune 70 & 170 hubs built by Troy at FWB.
Seat looks a little low in front but feels good on the road
Here's the build list:
Frame: Wilier Cento Uno w/integrated Ritchey WCS carbon headset
Wheels: Enve 3.4 Smart System (metallic red decals) w/Tune 70/170 (black) hubs and
Sapim CX-ray (black) spokes
Quick release: Tune DC14 (red)
Tires: Continental Competition (22mm.) w/Enve valve extenders
Gruppo: Dura Ace 7900
STI shifters/brake levers
brake calipers w/Enve pads
front derailleur
rear derailleur w/Enduro ‘zero’ ceramic pulleys (red)
crankset, compact
Cassette: KCNC titanium, 11/23
Chain: KMC X10SL (gold)
Cables & Housing: Yokozuna Reaction (white)
BB Bearings: Enduro ‘zero’ ceramic bearings
Stem: Ritchey WCS Carbon Matrix 4-Axis w/carbon weave finish
Bar: Ritchey Superlogic Carbon Evolution
Seat: Selle Italia SLR Kit Carbonio Flow (white)
Seat Mast Topper: Woodman IT Series
Pedals: Look Keo carbon titanium
Cage: Tune carbon
Bar Wrap: Deda Elementi, carbon-look (white)
Fourthbook
Cat 4
Re: Wilier Cento Uno: 6355 grams (14.01 lbs)
Postby rlpaul » Mon Nov 07, 2011 10:49 pm
Those red Enve decals are sweet. Always liked the look of Wiliers :)
rlpaul
Cat 2
Postby Fourthbook » Mon Nov 07, 2011 10:57 pm
Thanks. Unfortunately, the decals seem to be pretty fragile... not sure how long they'll last. I'll probably switch to a silver chain when replacing it. Too much contrast w/ the silver on the cranks. However, maybe Santa will bring me a Clavicula w/black/dark chainrings so I can keep the gold chain...
Fourthbook
Cat 4
Postby TheRedMantra » Fri Nov 11, 2011 9:36 am
I like the gold chain. It's a good candidate for the black/red kmc dlc chain.
TheRedMantra
Cat 4
Postby Fourthbook » Sat Nov 12, 2011 1:30 am
I agree: the black KMC X10Sl DLC chain would look great. But what I'd really like is a Clavicula crank, if it would fit the Wilier BB. Unfortunately, I'm told it won't work...
Fourthbook
Cat 4
Postby Fourthbook » Mon Nov 28, 2011 11:32 pm
I've decided to switch the crank from the DA-7950 to a Campy SR Ultra torque (2011 version w/titanium spindle) and then remove the decals. This should shave off nearly 100 grams and better match the color scheme. I think the Campy crank will be stunning w/o decals.
Has anyone removed the clear coat and decals on Campy carbon cranks? If so, what technique did you use and how did it turn out? I know Gumgardner has done so on other SR components using a razor; others swear by Carbo Lift, acetone, and various paint removers like Oops. And did you refinish w/ clear coat or carbon wax???
PS: Although I've had a tantalizing nibble, I'm searching for the crankset; see viewtopic.php?f=46&t=8439
Fourthbook
Cat 4
Postby über-goober » Tue Nov 29, 2011 1:50 am
I have stripped some other parts before but the SR cranks were really hard to do.. like a gelcoat or something else that's way tougher than a clear coat. I like the results but it didn't save any weight (638g complete with Italian cups).
über-goober
Cat 2
Postby Fourthbook » Tue Nov 29, 2011 3:27 am
Thanks for the response, Uber, but I didn't mean to suggest that the reason for removing the decals was to save weight; rather that the switch from DA to Campy would save nearly 100 grams. Removing the decals would be for aesthetics only (owner vanity)...
Fourthbook
Cat 4
Postby über-goober » Tue Nov 29, 2011 2:53 pm
Very handsome Wilier BTW
:applause: :D
über-goober
Cat 2
Postby Fourthbook » Tue Nov 29, 2011 4:58 pm
Thanks.
BTW: What method did you use to remove the clear coat & decal from the SR crank? I'd love to see a close up pic of the result as the contrast on the pic of the bike makes it hard to really see/appreciate your handiwork...
Fourthbook
Cat 4
Re: Update Wilier Cento Uno: 6101 grams (13.45 lbs), new pic
Postby Fourthbook » Thu Jan 05, 2012 11:13 pm
Made some holiday changes to the bike including Campy SR Ti crankset, black KMC-X10SL-DLC chain, black Lizard Skin bar tape and black PowerCordz Prime cables and housings. This brought the weight down to 13.45 lbs or 6101 grams. Thanks to those who answered my concerns about running a Campy 11 spd crank w/ a 10 spd chain, cassette and DA derailleurs. It works fine!
Fourthbook
Cat 4
Postby pritchet74 » Fri Jan 06, 2012 6:39 am
I wish that I could run those Enve wheels with my bike......
It's looking awesome and I can't believe how light it is!!!!!
pritchet74
Aerodymatic Man
Postby Fourthbook » Fri Jan 06, 2012 4:16 pm
Thanks, Pritch. I was pleasantly surprised w/ the new weight when we weighed the bike yesterday at my LBS on their Park digital scale. I'm a bit skeptical of the accuracy as I was expecting it to be about 13.75 lbs. Switching from the DA cranks to the Campy SR Ti cut about 120 grams. Perhaps the new Lizard Skin tape cut a few more grams over the prior Deda Elementi tape, and the new PowerCordz Prime cables/housings are certainly lighter than the Yokozuma but I don't know how much so (plus, we had to retain the Yoko steel cable for the RD b/c the PowerCordz cable wouldn't run smoothly thru the chain stay liner). Regardless, the steed felt spritely on my ride.
Hoping to visit Hearldsburg next autumn for some rides in Sonoma County...
Fourthbook
Cat 4
Re: Done: Wilier Cento Uno, 6.01 kg, new pics p. 2
Postby Fourthbook » Fri Aug 24, 2012 4:58 pm
I'm done tinkering with my ride, except for replacement parts: 6.01 kg or ~13.25 lbs for its daily ride set up as shown in the pics; just under 13 lbs with my climbing wheelset. The collage shows the evolution of the bike over the past year when read from upper left to lower right (current set up). Cheers!
Fourthbook
Cat 4
