Weight submissions
Tools to help you find real world weights.
Weight submissions
Postby madcow » Wed May 09, 2012 3:38 pm
Lately we've been working on an arrangement with the guys at WW to revive the listings there and to also expand them. The result is quite close to launching and we are ready to start accepting new submissions for the listings. We encourage everyone to submit their new components/frames that they have. We've made submissions very easy to do, simply select the proper form from the list below, fill it out and hit submit. Submissions will be collected, reviewed and then added to the listings database. The new listings format will be more robust than the current. It will be much easier to sort and index based on your specific requirements.
Bar ends, MTB
Bottle Cages
Bottom Brackets
Brakes, Disc
Brakes, Rim/Caliper
Brake Accessories Pads, Shoes, holders, hydrualic lines, rotors etc...
Brake Levers Brake levers, road or mtb, without integrated shifters.
Cables/Housing
Cassettes/Freewheels Cassettes, cogs, freewheels and lockrings.
Chainrings/Chainring bolts
Chains
Clothing Helmets, shoes, glasses etc...
Crank Arms Crank arms without bottom brackets.
Crank sets complete cranksets as sold. May include chainrings, bottom brakcets or both.
Derailleurs, Front Front derailleurs and parts.
Derailleurs, Rear Rear derailleurs and parts.
Forks, Rigid Road, CX, MTB forks without suspension.
Forks, Suspension Suspension mtb forks
Frame Accessories mtb rear shocks, Barrel adjusters, cable guides, pivots, chainstay protectors etc...
Frames Mtb Hardtail Weights should be given with cable guides and hangers but without seat collars, bottle cage bolts and headset parts.
Frames Mtb Full Suspension Please note if weight includes rear shock or not. Weights should be with cable guide and hanger, but without seat collar, bottle cage bolts and headsets.
Frames Road Weight should be given with cable guides, cable stops and hangers but without seat collars, bottle cage bolts and headset parts.
Grips/Tape Grips, Bar tape, handlebar plugs.
Handlebars, MTB
Handlebars, Road
Headset Accessories Top caps, bolts, spacers, expanders.
Headsets Complete headsets.
Hubs
Misc Accessories Computers, GPS, Power meters, Lights etc...
Pedals
Rims Mtb
Rims Road
Saddles
Seat collars
Seatposts
Shift/Brake levers Integrated shifter/brake levers.
Shifters Shifters without brake levers.
Skewers
Stems
Tires, MTB
Tires, Road
Tubes
Wheel Accessories Spokes, nipples, rim tape, valves and extenders etc...
Wheels Mtb
Wheels Road
madcow
Dork Overlord
Return to Weight Listings
