Forks
Specifications Weight, Uncut Steerer295gr. Steerer Tube O.D.1 1/8" Axle to Crown367 mm Rake43 mm About Enve Composites In late 2010, Edge...
$675.000 in stock.View
Specifications Weight, Uncut Steerer350 grams Steerer Tube OD1 1/8" Axle to Crown367 mm Rake43mm About Enve Composites In late 2010, Edge...
$480.001 in stock.View
Specifications Weight, Uncut Steerer450 grams Steerer Tube O.D.1 1/8" Axle to Crown395 mm Rake47 mm About Enve Composites In late 2010, Edge...
Specifications Weight, 300 mm Steerer 340 grams Weight, 200 mm Steerer 320 grams Weight, Rear Brake 50 grams Steerer Diameter 1 1/8 inch ...
$1,400.002 options.View
Specifications Weight, 300 mm Steerer 285 grams Weight, 200 mm Steerer 260 grams Steerer Diameter 1 1/8" Steerer Length 300, uncut Rake 44...
$1,000.000 in stock.View
Specifications Weight 3.5 grams Compatible Forks THM Scapula, Scapula SP, Scapula SP Tuned Detail Spina Scapulae is Latin for shoulder blade,...
$95.000 in stock.View
