Fibre-Lyte Carbon Compact Road Chainrings (110 BCD)
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 34T $130.00 Notify Me When Available
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 34T (Campy crank only) 10s $130.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 34T 11spd compatible $130.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 36T $130.00  1 Remaining
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 36T (Campy crank only) 10s $130.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 38T $130.00 Notify Me When Available
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 40T $175.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 42T $175.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 44T $175.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 46T $175.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 50T $175.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 50T (Campy crank only) 10s $175.00 In Stock
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 50T (Campy crank only) 11s $175.00 Notify Me When Available
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) 50T 11spd compatible $175.00 Notify Me When Available
Fibre-Lyte Carbon Compact Road Chainrings (110 BCD) Fibre-Lyte Carbon Compact $130.00 Notify Me When Available
Fibre-Lyte carbon fiber chainrings are available as a single ring for time trial racing for which they can last thousands of miles if well-maintained. They are also available as a double ring with lift pins and reduced profile teeth for smooth shifting. However, customers must ensure that if using the chainrings on a double setup, that they purchase the correct type of chainring, as using a chainring machined for a single on a double can damage the chainring. Please contact us for advice. All rings are custom made, any number of teeth on any BCD. Choice of weave styles also.
Comment on Fibre-Lyte Carbon Compact Road Chainrings (110 BCD)
