Far and Near SRAM Derailleur Tuning Kit
Far and Near SRAM Derailleur Tuning Kit Black$100.00 In Stock
Far and Near SRAM Derailleur Tuning Kit Gold$100.00 In Stock
Far and Near SRAM Derailleur Tuning Kit Red$100.00 In Stock
CompatibilitySRAM Road
ColorsBlack, Gold, Red
Contents
Front Derailleur
m5 x 16mounting bolt and washer
m3 x 18limit screws (2)
m5 x 9pinch bolt and washer
m4 x 6cage plate bolt
Rear Derailleur
m10 x 25main pivot bolt
m5 x 12reverse thread barrel adjuster
m4 x 14limit screws (2)
m4 x 20B limit screw
m5 x 8cable pinch bolt
m4 x 17upper pulley mounting bolt
m5 x 14lower pulley mounting bolt
m4 brass sleeve for upper pulley bolt
cartridge bearing pulley wheels, 11 tooth (2)
These derailleur tuning kits from Far and Near are designed to fit SRAM road derailleurs. Included are bolts and hardware for a set of front and rear derailleurs. Each 7075 aluminum component is precisely manufactured to match the derailleur's OE specification so there is no compromise in adjustability or functionality. Unlike color tuning kits from other manufacturers, every piece is anodized in the same batch to ensure perfect color matching.
Comment on Far and Near SRAM Derailleur Tuning Kit
