Far and Near S2 Stem, White
Far and Near S2 Stem, White 110 mm$90.00  $63.00
Save: $27.00 off
 1 Remaining
Weight, 80 mm 110 grams
Weight, 90 mm 116 grams
Weight, 100 mm 124 grams
Weight, 110 mm 135 grams
Weight, 120 mm 146 grams
Body Material 6061 aluminum
Faceplate Material 7075 aluminum
Bolt Material 6/4 titanium
Rise +/- 6 degrees
Handlebar Clamp 31.8 mm
Steerer Clamp 1 1/8 inch
Far and Near's S2 series stems use a lightweight faceplate and titanium bolts to save weight over their lesser expensive S1 stems. The stem's body is aggressively machined from a single block of 6061 aluminum for minimal weight while retaining a level of strength and stiffness on par with stems from better known manufacturers. These stems are powder coated white. The logos and markings are not painted, but rather etched into the stem's paint for a unique look.
Far and Near's Stems are suitable for Road and Cross Country use. The edges of both clamps are beveled, making them suitable for use with carbon forks and handlebars.
Comment on Far and Near S2 Stem, White
