Far and Near S1 Stem
Far and Near S1 Stem 80 mm$85.00  $59.50
Save: $25.50 off
In Stock
Far and Near S1 Stem 100 mm$85.00  $59.50
Save: $25.50 off
 1 Remaining
Far and Near S1 Stem 110 mm$85.00  $59.50
Save: $25.50 off
 2 Remaining
Far and Near S1 Stem 120 mm$85.00  $59.50
Save: $25.50 off
 2 Remaining
Weight, 80 mm 122 grams
Weight, 90 mm 127 grams
Weight, 100 mm 136 grams
Weight, 110 mm 144 grams
Weight, 120 mm 155 grams
Body Material 6061 aluminum
Faceplate Material 6061 aluminum
Bolt Material steel
Rise +/- 6 degrees
Handlebar Clamp 31.8 mm
Steerer Clamp 1 1/8 inch
Far and Near's S1 series stems feature a four bolt, one-piece faceplate with steel bolts for an excellent combination of low weight and durability. The stem's body is aggressively machined from a single block of 6061 aluminum for minimal weight while retaining a level of strength and stiffness on par with stems from better known manufacturers. These stems are anodized black with laser etched logos and size markings.
Far and Near's stems are suitable for Road and Cross Country use. The edges of both clamps are beveled, making them suitable for use with carbon forks and handlebars.
Comment on Far and Near S1 Stem
