Far and Near Pulley Wheel Set
Far and Near Pulley Wheel Set Black $40.00 Notify Me When Available
Far and Near Pulley Wheel Set Blue $40.00 In Stock
Far and Near Pulley Wheel Set Gold $40.00 In Stock
Far and Near Pulley Wheel Set Red $40.00 Notify Me When Available
Far and Near Pulley Wheel Detail
Weight11 grams per pulley
Material7075 aluminum
Bearing Size689
Pulley Size11 tooth
Derailleur CompatibilityShimano, Sram,
Campagnolo (10 spd)
Far and Near derailleur pulleys offer a colorful, durable, and functional alternative or replacement for manufacturer's stock pulleys. Stylistically machined from high grade 7075 aluminum, these spoked pulleys feature rubber seal cartridge bearings with an additional labyrinth style dust shield integrated into the bearing covers. This design includes a small amount of lateral float, allowing the upper pulley to self-align for quick and precise shifting response. Brass shims are included to adapt the pulleys to M4 mounting bolts, used on select Sram derailleurs.
Comment on Far and Near Pulley Wheel Set
