Far and Near
Far and Near Campagnolo Derailleur Tuning Kit
Specifications CompatibilityCampagnolo Road ColorsBlack, Gold, Red Contents Front Derailleur m5 x 15mounting bolt and washer m3 x 18limit screws...
$85.00
5 options.View
Far and Near Shimano Derailleur Tuning Kit
Specifications CompatibilityShimano Road ColorsBlack, Gold, Red Contents Front Derailleur m5 x 13mounting bolt and washer m4 x 11limit screws...
$100.00
3 options.View
Far and Near SRAM Derailleur Tuning Kit
Specifications CompatibilitySRAM Road ColorsBlack, Gold, Red Contents Front Derailleur m5 x 16mounting bolt and washer m3 x 18limit screws (2)...
$100.00
3 options.View
Far and Near 105 5700 Brake Hoods
Specifications The Far and Near company have created a line of colored brake hoods with similar look, feel, and weight of the stock manufacturers'...
$25.00
7 options.View
Far and Near 10s Campagnolo Brake Hoods
Specifications Far and Near company have created a line of colored brake hoods with a similar look, feel, and weight of the stock manufacturers'...
$25.00
6 options.View
Far and Near 11s Campagnolo Brake Hoods
$25.00
7 options.View
Far and Near Aluminum Campagnolo Cassette Lockring
Specifications Weight 5 grams Colors Black, Blue, Gold, Green, Red, Silver Sizes 11t, 12t Details Far and Near's aluminum lockrings are...
$15.00
12 options.View
Far and Near Aluminum Shimano Cassette Lockring
$15.00
12 options.View
Far and Near Butterfly Flat Pedals
Specifications Weight per Pair ~232 grams Spindle Material 6/4 titanium Body Material 6061 aluminum Application commute, cross country, BMX ...
$150.00
5 options.View
Far and Near Cable Tips
Package of 25 cable end caps. Black, Blue, Gold, Green, Purple and Red. Fits either brake or shift cables.
$7.00
6 options.View
Far and Near Carbon Fiber Bottle Cage
Specifications MaterialCarbon Fiber Weight21 grams Colors3k nude, White Detail Far and Near carbon fiber bottle cage. Even though at 21 grams it's...
$50.00  $40.00
Save: $10.00 off
2 options.View
Far and Near Carbon Mountain Skewers
Specifications Weight42 grams Axle Material6/4 titanium Handle Material7075 aluminum / carbon fiber Usecross country, trail Detail Far and Near's...
$70.00
5 options.View
Far and Near Carbon Road Skewers
Specifications Weight42 grams Axle Material6/4 titanium Handle Material7075 aluminum / carbon fiber Useroad Detail Far and Near's titanium quick...
$70.00
5 options.View
Far and Near Chain Deflector
Specifications Weight w/ Bolt and Spacer 5.6 grams Compatibility braze-on derailleur tabs only Material 7075 aluminum Detail A...
$28.00
4 options.View
Far and Near Chainring Bolts
Specifications Weight9.6 grams per set Material7075 aluminum Bolt Threadm8 x 8.5 Nut Threadm8, 6.7 mm sleeve Detail Far and Near's aluminum...
$16.00
6 options.View
Far and Near Compact Road Chainrings (110 BCD)
Specifications Weight 135g Sizes 50/34t BCD 110mm BCD Colors Anodized Blue and Black Anodized Bronze and Black Anodized Gold and Black...
$130.00  $97.50
Save: $32.50 off
1 options.View
Far and Near Disc Brake Rotor
Specifications Weight, 160 mm114 grams Weight, 180 mm129 grams
$50.00  $35.00
Save: $15.00 off
10 options.View
Far and Near Dura-Ace 7800 Brake Hoods
$25.00
6 options.View
Far and Near Dura-Ace 7900 Brake Hoods
$25.00
7 options.View
Far and Near Ferrules 4mm
Far and Near's anodized ferrules give you yet another way to add a little bit of style to your bike. These ferrules are CNC machined from aluminum,...
$10.00
4 options.View
Far and Near Ferrules 5mm
$10.00
4 options.View
Far and Near Flat Handlebar
Specifications Weight 135 grams Width 600 mm Back Sweep 8 degrees Stem Clamp Diameter 31.8 mm Detail This T7 Scandium-Aluminum flat...
$60.00
2 options.View
Far and Near Headset Spacers
Specifications Weight, 3 mm 3 gramsWeight, 5 mm 5 grams Weight, 8 mm 8 grams Inner Diameter 28.6 mm (1.125") Outer Diameter 36.2 mm ...
$2.00
10 options.View
Far and Near Housing Covers
Specifications Weight 1.7 grams each Housing Compatibility 4 mm, 5mm Available Colors black, blue, celeste, red, white, yellow Detail These...
$8.00
7 options.View
Far and Near Mountain Chainrings (104 / 64 BCD)
Specifications Weight 129g Sizes 44t/32t, 22t BCD, 44t/32t 104mm BCD BCD, 22t 64mm BCD Bold Pattern 4 Bolt Pattern Colors Anodized Blue...
$145.00  $108.75
Save: $36.25 off
2 options.View
Far and Near MTB Skewers
Closeout - 25% Discount! The Far and Near MTB Skewers feature a titanium axle, anodized aluminum levers and nuts to create a stylish lightweight...
$70.00  $52.50
Save: $17.50 off
5 options.View
Far and Near Pulley Bolts for 11 Speed Campagnolo
Specifications Weight 2.0 grams per pair Compatibility 11 speed Super Record, Record, and Chorus Available Colors black, blue, gold, green,...
$10.00
6 options.View
Far and Near Pulley Wheel Set
Specifications Weight11 grams per pulley Material7075 aluminum Bearing Size689 Pulley Size11 tooth Derailleur CompatibilityShimano, Sram, Campagnolo...
$40.00
4 options.View
Far and Near Road Brakes
Specifications Weight218 grams, complete Arm Material7075 aluminum Return Springstainless steel Hardware6/4 titanium Reach40-55 mm Available...
$290.00
3 options.View
Far and Near Road Chainrings (130 BCD)
Specifications Weight 150g Sizes 53/39t BCD 130mm BCD Colors Anodized Blue & Black Anodized Bronze & Black Anodized Gold...
$130.00  $97.50
Save: $32.50 off
2 options.View
Far and Near Road Skewers
Closeout - 25% Discount! The Far and Near Road Skewers feature a titanium axle, anodized aluminum levers and nuts to create a stylish lightweight...
$70.00  $52.50
Save: $17.50 off
3 options.View
Far and Near Shimano 105/Ultegra Brake Hoods
$25.00
6 options.View
Far and Near SRAM Brake Hoods
$25.00
6 options.View
Far and Near Titanium Rotor Bolts
Specifications Weight per Set ~14 grams Bolt Thread M5 x 10 mm Details This lightweight titanium rotor bolt set from Far and Near includes 12...
$50.00
5 in stock.View
Far and Near Ultegra 6700 Brake Hoods
$25.00
6 options.View
Far and Near S1 Stem
Specifications Weight, 80 mm 122 grams Weight, 90 mm 127 grams Weight, 100 mm 136 grams Weight, 110 mm 144 grams Weight, 120 mm 155...
$85.00
5 options.View
Far and Near S2 Stem, White
Specifications Weight, 80 mm 110 grams Weight, 90 mm 116 grams Weight, 100 mm 124 grams Weight, 110 mm 135 grams Weight, 120 mm 146 grams ...
$90.00
5 options.View
