Far and Near LED Bar End Plugs
Sign Up For Our Newsletter
You're Signed Up!
Weight28.9 grams
Material6065 Aluminum
Battery1.5v Button Cell: 4 per set
Far and Near LED Bar End Plugs Black $50.00 In Stock
Light up your ride with these bar end plugs from Far and Near. They use two LEDs in each plug to help make sure you’re seen at night. They’re made of sturdy aluminum and will last longer than plastic versions. The plug mechanism is actually quite clever, stick them in the end of your bar and tighten the end clockwise to expand the wedge.
