Far and Near Housing Covers
Far and Near Housing Covers Black $8.00  9 Remaining
Far and Near Housing Covers Blue $8.00 Notify Me When Available
Far and Near Housing Covers Celeste $8.00 In Stock
Far and Near Housing Covers Pink $8.00 In Stock
Far and Near Housing Covers Red $8.00 In Stock
Far and Near Housing Covers White $8.00 In Stock
Far and Near Housing Covers Yellow $8.00 In Stock
Weight 1.7 grams each
Housing Compatibility 4 mm, 5mm
Available Colors black, blue, celeste, red, white, yellow
These colorful cable housing covers, manufactured by Far and Near, are designed to protect your frame's paint and prevent cable rattle. They are molded with the same silicone as Far and Near's line of brake hoods in six matching colors. Each package includes four 4.5 cm long housing covers.
To install Far and Near housing covers, no dis-assembly of the cable system is required. Each cover is split along its length for quick and easy placement, and the silicone material securely grips the housing to prevent slippage.
Comment on Far and Near Housing Covers
