Far and Near Garmin Computer Mount
Sign Up For Our Newsletter
You're Signed Up!
Weight 34 grams
Handlebar Compatibility 31.8mm clamp diameter
Garmin Compatibility All twist lock computers including 200, 500, 510, 800, and 810
Material Machined 7075 aluminum
Far and Near Garmin Computer Mount Black $45.00 In Stock
Far and Near Garmin Computer Mount Red $45.00  1 Remaining
Far and Near Garmin Computer Mount Silver $45.00 Notify Me When Available
Far and Near Garmin Computer Mount Gold $45.00 Notify Me When Available
Far and Near Garmin Computer Mount Blue $45.00 In Stock
Details
The stock Garmin computer mounts may leave a lot to be desired. Especially with the large head units like the 810 model, you give up a lot of space mounting it on your handlebars. The stem is an option but the head unit rests up fairly high and the viewing angle can be less than ideal. This has created the demand for an improved mount for Garmin computers. Far and Near's Garmin mount is a simple and elegant solution designed to streamline your computer to be flush with your handlebar and stem. The mount, available in five anodized colors features a simple tool-free length adjustment allowing you to swap between computers of different sizes and or tweak your adjustment on the fly if needed. The machined alloy Garmin mount from Far and Near comes in at a feathery 34 grams. Bar clamp hardware requires a 3mm hex wrench.
Comment on Far and Near Garmin Computer Mount
