Far and Near Chainring Bolts
Far and Near Chainring Bolts Black$16.00 In Stock
Far and Near Chainring Bolts Blue$16.00 In Stock
Far and Near Chainring Bolts Gold$16.00 In Stock
Far and Near Chainring Bolts Green$16.00 In Stock
Far and Near Chainring Bolts Red$16.00 In Stock
Far and Near Chainring Bolts Silver$16.00 In Stock
Weight9.6 grams per set
Material7075 aluminum
Bolt Threadm8 x 8.5
Nut Threadm8, 6.7 mm sleeve
Far and Near's aluminum chainring bolts offer an inexpensive and simple option for color- and weight-tuning your bicycle. These bolt and nut sets are available in six popular colors with laser etched graphics and save about 15 grams over a set of steel chainring bolts.
Each package includes a set of five bolts and nuts. Far and Near Chainring Bolts are designed for road double cranksets, but are compatible with any crankset that uses a standard double chainring bolt design.
Far and Near Chainring Bolts require a 4mm hex wrench. A chainring nut tool may also be required. We recommend installing aluminum chainring bolts with a medium strength loctite for additionaly security. When using a torque wrench, tighten to 10 Nm.
Comment on Far and Near Chainring Bolts
