Far and Near Campagnolo EPS Brake Hoods
Sign Up For Our Newsletter
You're Signed Up!
Compatability Campagnolo 11spd EPS
Contents Two Brake Hoods
Far and Near Campagnolo EPS Brake Hoods Black $30.00 In Stock
Far and Near Campagnolo EPS Brake Hoods Blue $30.00 In Stock
Far and Near Campagnolo EPS Brake Hoods Celeste $30.00  1 Remaining
Far and Near Campagnolo EPS Brake Hoods Green $30.00 In Stock
Far and Near Campagnolo EPS Brake Hoods Pink $30.00 In Stock
Far and Near Campagnolo EPS Brake Hoods Red $30.00 In Stock
Far and Near Campagnolo EPS Brake Hoods White $30.00 In Stock
Far and Near Campagnolo EPS Brake Hoods Yellow $30.00 In Stock
The Far and Near brake hoods are the closest feeling to original brake hoods that we've felt here at Fairwheel. The reason for this is that Far and Near takes a sample of the stock brake hood and reverse engineers the rubber compound for every manufacturer and model before beginning production. Aside from the feel the shape and fit to the levers themselves is superior to any aftermarket hood. Overall the differences will be subtle and all you should notice is a nice color change to better match your frame or kit.
Far and Near highly recommends removing your levers from your bars and istalling the hoods from the back of the lever. This prevents the lever from cutting the hood as it's slid over the front of the lever. We've found that using a mild soap solution helps lubricate during installation and dries tacky keeping the grip in place. Another good option is hairspray but this dries faster.
Comment on Far and Near Campagnolo EPS Brake Hoods
