Fair Wheel Skrull Clydesdale Wheelset
Sign Up For Our Newsletter
You're Signed Up!
Weight1760 grams
Front HubDT 350
Rear HubDT 350
SpokesSapim Race
RimKinlin XC-279
Spoke Count28 hole front, 28 hole rear
Intended UseRoad Training, CX, Dirt Roads
Fair Wheel Skrull Clydesdale Wheelset Shimano $450.00  1 Remaining
Fair Wheel Skrull Clydesdale Wheelset Campagnolo $450.00 Notify Me When Available
Details
Introducing the Skrull, our stock heavy hitter, gravel grinder or Cx wheelset. Designed and built by our master wheel builders, the Skrull is ideal for riders up to 220 lbs, or for those intending to consistently punish their wheels on rough gravel roads. Constructed with ultimate durability in mind, the Skrull utilizes the wider profile Kinlin XC-279 rims laced with Sapim Race spokes to DT Swiss 350 hubs, resulting in a considerably bomb proof wheelset.
Kinlin XC279 Rims
Constructed from lightweight extruded niobium-aluminum alloy, the XC-279 rim features a slightly wider 23mm profile that results in a wider tire contact patch with the ground and slightly better aerodynamics.
DT 350 Hubs
The leading name in budget minded durability, the DT 350 hub is arguably the best bang for your buck. Weighing in at an impressive 149 g and 252 g package front and rear, while simultaneously combining the best traits of serviceability, price, and longevity, the DT 350 is sure to impress even the elite echelon.
Sapim Race Spokes
The ultimate middle ground between price and weight. The Sapim Race spoke can be seen on an array of wheelsets from carbon climbers to abused mountain wheels. Using a proprietary forging process, Sapim is able to “stretch” each spoke’s midsection, essentially saving weight while raising tensile strength and fatigue life.
