Fair Wheel Kalloy Uno Stealth Stem
Article number: | 09-03-02 |
Availability: | In stock (46) |
Meticulously forged from 7050 T6 aluminum, the Kalloy Uno represents the ideal median between price and performance. With a weight comparable to much more expensive options, the Uno easily finds its place among even the most elite builds. By utilizing a CNC controlled variable thickness internal structure, Kalloy is able to refine the performance and weight characteristics of the Uno, enabling it to have an impressive stiffness-to-weight ratio. With a completely minimalist design featuring no logos, the Uno is the ideal choice for those looking to complete that stealth look for their next build.
TITANIUM BOLT UPGRADE: Run it as is, or pair it with black, blue, gold, or rainbow titanium hardware for increased weight savings and a uniform aesthetic. Follow the link here and select the color you want from the drop down menu and add to cart.
*The newest Kalloy stem has a 1 piece faceplate. This adds 2 grams. Half the stems have the separated faceplate and the other half has the one piece. We will be sending them out at random per order. Email or call us if you have a preference when you order and we can switch them out.
Hardware | Stainless Steel | |
Handlebar Clamp ø | 31.8mm | |
Steerer Clamp ø | 28.6mm | |
Length | Weight w/ steel bolts | Weight w/ titanium bolts |
60mm | 96 grams | 87 grams |
70mm | 98 grams | 89 grams |
80mm | 100 grams | 91 grams |
90mm | 102 grams | 93 grams |
100mm | 107 grams | 98 grams |
110mm | 110 grams | 101 grams |
120mm | 117 grams | 108 grams |
130mm | 129 grams | 120 grams |
**Add 2 grams to all weights for 1 piece faceplate.**
