Extralite Ultrastar 2 Expander
Sign Up For Our Newsletter
You're Signed Up!
Weight 7 grams
Compatible Steerer Tube I.D. 22.8 to 25.2 mm
Material 7075 T6 aluminum
Torque 7-8Nm
Use road, cross country
Product Manuals
Ultrastar 2 Expander Plug Manual
Extralite Ultrastar 2 Expander Ultrastar 2 $42.00 Notify Me When Available
Details
The latest iteration of Extralite's expander plug for threadless headsets is about as light they come. The Ultrastar 2 uses a simple and incredibly secure dual wedge design with a range of adjustments to fit most modern steerer tubes. Extralite's attention to detail is clearly evident, with five masterfully machined individual pieces. A hard anodized coating on the upper and lower wedges helps prevent corrosion.
The Ultrastar 2 is 100% designed and manufactured in Italy.
Ordering
Please accurately measure the inner diameter of your fork's steerer tube before ordering to ensure compatibility.
File the top of the steer-tube to avoid sharp edges. Holding the bottom (red) cone in your hand tighten the Ultrastar2 until you can slide it into your steer tube with some pressure on the inner walls. Make sure your stem is installed and properly tightened before torquing the ultra star in place, 5-10mm below the lip of the steertube. Finally tighten Ultrastar2 to 7-8Nm.
Warnings
As with all expander plugs and carbon fiber steer tubes never install the Ultrastar2 without a stem properly installed. Always remember to tighten stem clamp before riding. (Respect manufacturer reccommended torque). Ultrastar cannot hold a loose stem while riding.
