Extralite UltraPost Seatpost
Sign Up For Our Newsletter
You're Signed Up!
Weight, 250 mm99 g
Weight, 350 mm136 g
ApplicationsRoad, Cross Country
Post Material7075 T6 Aluminum
Clamp Material7075 T6 Aluminum
HardwareGRD 5 Titanium
Max Bolt Torque3.5 nm
Product Manuals
UltraPost Owners Manual
Extralite UltraPost Seatpost 31.6 x 250 mm, Black $250.00 Notify Me When Available
Extralite UltraPost Seatpost 31.6 x 350 mm, Black $250.00 Notify Me When Available
UltraPost Details
The UltraPost is one of the lightest in the world, even besting most carbon fiber seatposts. The 7075 Aluminum shaft is butted, and shaped in different ways internally and externally in order to create flex in areas for comfort, and stiffness in others where comfort is not required. The clamp is designed to work both with standard round saddle rails, as well as ovalized carbon fiber rails, making this a versatile seatpost for the most elegant, lightweight builds of all.
Such a unique design requires specific installation instruction. Seatpost clamp bolts are to be torqued specifically to 3.5Nm. Also, each post has a specific minimum and maximum insert length due to its butted construction.
The minimum insert for the 250mm post is 70mm, while the 350mm post is 90mm, and the maximum insert for the 250mm is 100mm, while the 350mm is 200mm.
Comment on Extralite UltraPost Seatpost
