Extralite UltraFront SX Hub
Extralite UltraFront SX Hub 16 Hole$210.00  1 Remaining
Extralite UltraFront SX Hub 20 Hole$210.00 In Stock
Extralite UltraFront SX Hub 24 Hole$210.00  1 Remaining
Weight49 grams
Bearing Size6801 (2)
Axle Diameter14 mm
Available Drillings16, 18, 20, 24 hole
Hub Shell Material7075tx aluminum
Useroad only
Wheel Building Dimensions
Flange Diameter29 mm
Center to Flange38 mm
Extralite's SX front hub is one of the lightest front hubs available, and makes some significant improvements over its predecessor, the Ultrafront SL. Relative to the SL, the spoke flanges of the SX have been moved out 4mm on each side, resulting in increased lateral stiffness of the complete wheel. Also, the hub shell, flanges, and axle ends have been reduced in size to save 12g over the Ultrafront SL. As with all Extralite products, the finish work on the hub shell, flanges, and axle is immaculate.
The SX features an easily adjustable bearing preload micro tuner. It is imperative that the micro tuner be properly adjusted to avoid damage to the bearings, axle, or the micro tuner itself. Due to the nature of this system, the hub is directional and must be oriented correctly in the fork. The hub shell is marked to indicate proper orientation.
100% made in Italy.
Assembly
We recommend that Extralite hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on Extralite UltraFront SX Hub
