Extralite UltraFront SPM Hub
Extralite UltraFront SPM Hub 16 Hole$210.00  1 Remaining
Extralite UltraFront SPM Hub 20 Hole$210.00 Notify Me When Available
Weight47 grams
Bearing Size6801
Available Drillings16, 20, 24 hole
Hub Shell Material7075 aluminum
Wheel Building Dimensions
Flange Diameter26 mm (straight pull)
Center to Flange42.5 mm
Extralite's straight pull front road hub design, the SPM, is their lightest at 47 grams. The drillings have been moved out on each side, resulting in increased lateral stiffness of the complete wheel.
Further features of the UltraFront SPM hub:
Hub flanges are specially heat treated to handle the stresses of radial spoke lacing.
Finish: black anodizing with laser-cut logos. Axle ends are specially hard-anodized.
For road use only.
100% made in Italy.
As with all Extralite products, UltraHubs exceed the European UNI/DIN Safety standards. Extralite's safety tests simulate a very strong 90kg (200lb) rider output.
Assembly
We recommend that Extralite hubs, especially the SPM be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on Extralite UltraFront SPM Hub
