Extralite Ultraclamp Seatpost Collar
Extralite Ultraclamp Seatpost Collar 31.8 mm, Black$40.00 Notify Me When Available
Extralite Ultraclamp Seatpost Collar 31.8 mm, Blue$40.00 In Stock
Extralite Ultraclamp Seatpost Collar 31.8 mm, Gold$40.00 Notify Me When Available
Extralite Ultraclamp Seatpost Collar 31.8 mm, Green$40.00 Notify Me When Available
Extralite Ultraclamp Seatpost Collar 31.8 mm, Purple$40.00  2 Remaining
Extralite Ultraclamp Seatpost Collar 31.8 mm, Red$40.00  2 Remaining
Extralite Ultraclamp Seatpost Collar 34.9 mm, Black$40.00  2 Remaining
Extralite Ultraclamp Seatpost Collar 34.9 mm, Blue$40.00 Notify Me When Available
Extralite Ultraclamp Seatpost Collar 34.9 mm, Gold$40.00 In Stock
Extralite Ultraclamp Seatpost Collar 34.9 mm, Green$40.00  2 Remaining
Extralite Ultraclamp Seatpost Collar 34.9 mm, Orange$40.00  1 Remaining
Extralite Ultraclamp Seatpost Collar 34.9 mm, Purple$40.00  1 Remaining
Extralite Ultraclamp Seatpost Collar 34.9 mm, Red$40.00 In Stock
Weight11gr.
CollarCNC machined Ergal 7075 T6
BoltCNC Ti Grade 5
ColorsBlack, Blue, Gold, Green, Purple, Red
The Ultraclamp, like every other Extralite product, is designed with a fanatical attention to detail, and engineered to be the best possible component at the lightest possible weight. While relatively commonplace in appearance, the Ultraclamp's superiority is revealed in the details. The lower edges of the clamp are rounded on the inside to ease installation and prevent seat tube scratches. Similarly, the upper edges of the inner clamping surface are relieved to take pressure off the delicate upper edge of carbon seat tubes. The taper-head titanium clamp bolt sits within a machined slot, and the remaining outer portion of the clamp is beautifully finished: polished and anodized in a variety of colors.
Comment on Extralite Ultraclamp Seatpost Collar
