Extralite
Extralite's rear derailleur pulleys are Shimano and Campagnolo compatible. An excellent after-market replacement component, Extralite's pulleys are a...
$58.001 in stock.View
Specifications Weight 59 grams Material Ergal lever, titanium axle Details The really accurate lever design, ergonomic with rounded edges, the...
$140.004 options.View
The design of Extralite hubs requires the use of an additive-free, lightweight synthetic grease in order to protect and lubricate the internal o-ring...
$12.003 in stock.View
Specifications Weight9 grams per set Material7075 T6 aluminum Recommended Torque5-6 Nm Detail Extralite's chainring bolts are precision machined...
$24.000 in stock.View
Extralite's Cyberends are an even lighter version of the Ultraends, CNC-machined from a solid block of 7075 T6 aluminum using sophisticated 3D...
$135.002 options.View
Extralite's Extrabolt 10 headset spacer kit for 1-1/8" steerer tubes. Includes two 5mm and one 10mm spacers. Artistically machined from strong and...
$25.005 in stock.View
Specifications Weight, Complete484 grams Bearing Size6806 (2) Bolt Circle Diameter110 mm (compact) Spindle Diameter27 mm Bottom Bracket OptionsBSA,...
$660.003 options.View
Specifications Weight 498 grams Crank Length 172.5mm BCD 104 / 64 5 bolt Q Factor 160 mm Bearings 6806 Spindle...
$468.000 in stock.View
Specifications Weight 498 grams Crank Length 175 mm BCD 104 / 64 5 bolt Q Factor 160 mm Bearings 6806 Spindle...
$468.001 in stock.View
Specifications Weight 82g Size 28t/42t Colors Black/Ti anodized finish BCD 104mm Bolt Pattern 4 bolt pattern Shift Ramps CNC'ed Shift...
$174.001 in stock.View
Extralite infuses every bit of their artistry and mechanical creativity into all the products they create, and their line of headsets is no...
$160.003 options.View
Specifications Weight 68 grams Material 7075 aluminum Bearing Sizes 6803 (2) Available Spoke Drillings 24, 28, 32 Detail The Extralite...
$270.005 options.View
Specifications Weight84 grams Bearing Size6902 (1), 6805 (2) Available Drillings28, 32 hole Hub Shell Material7075tx aluminum...
$270.003 options.View
Specifications Weight 168 grams Material 7075 aluminum Bearing Sizes 6803x2, 6903x2 Available Spoke Drillings 28, 32 Detail The Extralite...
$600.004 options.View
Specifications Weight 107g/set Material Ergal 7075T6 Construction Hyper Accurate CNC Ramps 5 cnc with unique 15 degree profile Machined...
$175.001 in stock.View
Specifications Weight, 22t 16g Weight, 32t 33g Weight, 44t 61g Sizes 104x22/32/44 Material Ergal 7075T6 Construction Hyper Accurate CNC ...
$28.004 options.View
Specifications Weight94 grams per set Tooth Count50 / 34 Material7075 T6 aluminum Bolt Circle Diameter110 mm (compact) Detail Extralite R oad C...
$200.001 in stock.View
Specifications Weight 5 grams Details Disc rotor bolt set, includes 6 pieces. GRD5 Titanium.
$45.000 in stock.View
Specifications Weight4.6 grams Bolt DimensionsM6 x 20 Detail This is the top cap included with every Extralite headset - expertly machined from...
$35.007 options.View
Much lighter, simpler and more elegant than carbon fiber competitors. Graphics: laser etched. Clamp: AL 7075 T6 Ergal CNC. Tube: triple butted AL...
$164.004 options.View
Specifications Weight 99 grams/set Details Four sealed ball bearings ensure a constant position of return springs. Return springs are made with...
$198.000 in stock.View
Specifications Weight 64 grams/set Material Ergal 7075TX Construction hyper accurate CNC. Compatibility Grip and Trigger shifters Tuning...
$198.001 in stock.View
Specifications Weight 105 grams Width 560 mm Bend 4 degrees Clamp Size 25.4 mm Details This is one of the lightest flat MTB bars we sell...
$135.001 in stock.View
Specifications Weight11gr. CollarCNC machined Ergal 7075 T6 BoltCNC Ti Grade 5 ColorsBlack, Blue, Gold, Green, Purple, Red Detail The Ultraclamp,...
$40.0013 options.View
Specifications Weight64 grams Bearing Size6803 Drilling Options16, 18, 20, 24, 28, 32 hole Hub Shell Material7075 aluminum Wheel Building...
$180.002 options.View
The Extralite UltraFront SPD hub is one of the lightest disc hubs ever at 98g. The front and rear hubs come in at an astonishing 296g, which allows...
$234.00 $163.80Save: $70.20 off
1 in stock.View
Specifications Weight47 grams Bearing Size6801 Available Drillings16, 20, 24 hole Hub Shell Material7075 aluminum Wheel Building Dimensions ...
$210.002 options.View
Specifications Weight49 grams Bearing Size6801 (2) Axle Diameter14 mm Available Drillings16, 18, 20, 24 hole Hub Shell Material7075tx aluminum...
$210.003 options.View
Extralite's UltraGrips are flat bar grips for the weight conscious rider. At only 16g for the pair, they are a significant weight savings over...
Specifications Weight 135 grams Width 600 mm Bend 6 degrees + 6 degrees Clamp Size 25.4 mm Rise 15 mm Details This is one of the...
$145.001 in stock.View
Specifications Weight139 grams Bearing Size6803 (2), 6903 (1) Axle Diameter17 mm Available Drillings20, 24, 28 hole Hub Shell Material7075 aluminum...
$480.003 options.View
Specifications Weight133 grams Bearing Size6803 (2), 6903 (1) Axle Diameter17 mm Available Drillings20, 24, 28 hole Hub Shell Material7075 aluminum...
$550.002 options.View
Specifications Weight135 grams Bearing Size6803 (2), 6903 (1) Axle Diameter17 mm Available Drillings20, 24, 28 hole Hub Shell Material7075 aluminum...
$480.006 options.View
Specifications Weight7 grams Compatible Steerer Tube I.D.23.3-25.2 mm Material7075 T6 aluminum Useroad, cross country Detail The latest iteration...
$40.000 in stock.View
Specifications Weight 100mm 83 grams Lengths 90mm, 100mm, 110mm Detail Extralite's New MTB OC features Hyper accurate dimensional engineering...
$230.003 options.View
Specifications Weight 100mm 83 grams Lengths 90mm, 100mm, 110mm Angle +/-8 degrees Detail Extralite's New Roadstem OC features Hyper...
$230.004 options.View
Specifications Weight 100mm 82 grams Lengths 90mm, 100mm, 110mm Angle +/-4 degrees Detail Extralite's New Ultrastem UL3 features Hyper...
Specifications Weight 110mm 87 grams Lengths 90mm, 100mm, 110mm Angle +/-8 degrees Clamp Diameter 26.0 mm Detail Extralite's New Roadstem...
