Extralite Hyperstem
Extralite Hyperstem
Extralite Hyperstem
Extralite Hyperstem
Extralite Hyperstem
Extralite Hyperstem
Sign Up For Our Newsletter
You're Signed Up!
Weight, 90 mm75 grams
Weight, 100 mm80 grams
Weight, 110 mm84 grams
Material7075 Txx aluminum
HardwareGrade 5 titanium
Stem Angle+/- 12 °
Clamp Diameter31.8 mm
Steerer Clamp Diameter1-1/8"
Recommended UseRoad, Cyclocross, XC, Enduro
Extralite Hyperstem 90 mm $230.00 Notify Me When Available
Extralite Hyperstem 100 mm $230.00 Notify Me When Available
Extralite Hyperstem 110 mm $230.00  1 Remaining
Details
Extralite has been manufacturing elite components for the cycling world since their beginning in 1995. Based out of Lodi, Italy, Extralite has been crafting a name for themselves by designing and producing some remarkably lightweight components, staying true to the name. Each component produced by Extralite is not only incredibly light, but also is subject to rigorous testing to ensure safety and ultimate durability. Many of their components pass the strenuous EN safety standard with flying colors.
The Hyperstem is no exception by any means. Tested well beyond the EN safety standard, Extralite is confident that the Hyperstem be used in any riding application, up to enduro. 3D CNC machined from a solid piece of 7075 Txx aluminum, resulting in extreme rigidity. The overall stiffness assists in the conservation of expended energy through the handlebars, which becomes important in sprints and climbs. Equipped with grade 5 titanium hardware to shave as much weight off the already trim design as possible, the Hyperstem is an ideal option for the rider conserned with overall build weight. Easy to install with your current bar setup without unraveling any bar tape, the Hyperstem uses a simple 2 piece, 4 bolt faceplate design and is compatible with all 31.8 mm clamp diameter bars.
