Extralite HyperRear Disc Hub
Extralite HyperRear Disc Hub Black, 28 Hole$600.00 Notify Me When Available
Extralite HyperRear Disc Hub Black, 32 Hole$600.00 Notify Me When Available
Extralite HyperRear Disc Hub Green, 32 Hole$600.00  1 Remaining
Extralite HyperRear Disc Hub Red, 32 Hole$600.00 Notify Me When Available
Weight 168 grams
Material 7075 aluminum
Bearing Sizes 6803x2, 6903x2
Available Spoke Drillings 28, 32
The Extralite HyperRear hub is one of the lightest disc hubs ever at 168g. The Hyper Rear hub features front engagment cassette driver that can withstand over a half-ton of chain pull. The front and rear hubs come in at an astonishing 246g, which allows for the building of an exceptionally light wheelset. However, nothing about this hub is micro. The rear hub uses 2- 6803 and 2- 6903 RS bearing, and a 17mm axle. The hub body is 7075TX aluminum, anodized black, with laser etched graphics. The hub flanges utilize a straight pull spoke system to reduce lateral flex and increase torque transmission.
Service
Extralite hubs feature carefully designed rubber o-ring seals and lightweight ratcheting mechanisms which require frequent service to ensure long life and maximum performance. This service is easily performed with simple hand tools. An instruction manual for the HyperRear Disc hub is provided here:http://www.extralite.com/Manuals/HyperRear.pdf
Extralite strongly recommends the use of their Alugrease Super 1 when lubricating the HyperRear's o-rings, bushings, and drive rings.
Comment on Extralite HyperRear Disc Hub
