Extralite HyperLefty Disc Hub
Extralite HyperLefty Disc Hub Black, 28 Hole$270.00  1 Remaining
Extralite HyperLefty Disc Hub Black, 32 Hole$270.00  1 Remaining
Extralite HyperLefty Disc Hub Green, 32 Hole$270.00 Notify Me When Available
Weight84 grams
Bearing Size6902 (1), 6805 (2)
Available Drillings28, 32 hole
Hub Shell Material7075tx aluminum
CompatibilityCannondale Lefty fork only
Wheel Building Dimensions
See Extralite's spoke length tables here.
The HyperLefty is an incredible 86g, making it the lightest front disc hub on the market. Intended for cross country use, the HyperLefty utilizes a sealed ABEC 5 2RS low friction bearing to achieve smooth action and easy maintenance. The hub body is CNC machined from 7075 series aluminum and anodized black with laser etched graphics.
The real beauty of the HyperLefty is the wheel it builds to. The hub utilizes straight-pull spokes, in a radial (non-drive side) and 2 cross pattern (drive side) to achieve one of the stiffest, strongest left wheels available.
100% designed and manufactured in Italy.
Assembly
We recommend that wheels with Extralite hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here.
Comment on Extralite HyperLefty Disc Hub
