Extralite HyperGrips
Sign Up For Our Newsletter
You're Signed Up!
Weight, Grips7.8 grams per pair
Weight, Bar Plugs4.0 grams per pair
Handlebar Diameter22.2 mm
MaterialEVA foam
Extralite HyperGrips HyperGrips $25.00  1 Remaining
Details
Extralite's HyperGrip foam grips are the very lightest available for weight-conscious cross country racers; up to 50 grams may be saved over similar grip designs. The thick, featherweight EVA foam offers a surprising amount of comfort, with ergonomically friendly rounded edges and subtle embossed surface logos.
To prevent slipping, Extralite UltraGrips must be installed with adhesive (not included). Common wood glue is recommended. Apply a small amount of adhesive to the inside of each grip, slide on and align position. The glue must be allowed to dry completely over a 24 hour period.
