Extralite Ebones W Crankset
Weight498 grams
Spindle Diameter22 mm
Q Factor160 mm
Crank Length175 mm
BCD104 / 64 (5 bolt)
Bottom Bracket68 / 73 BSA
Bearings6806
Product Manuals
Ebones W BSA Manual
Details
The Ebones W crankset is Extralite's mountain triple crankset. This innovative outboard bearing crankset features Extralite's signature three dimensional CNC milling, which creates a beautiful, complex design on the face of the cranks. The insides of the arms feature Extralite's patented Stress Split Profile, which serves to greatly reduce the weight of the arms. Through these processes, a maximum amount of material is removed while retaining optimal strength and stiffness. These cranks also have a narrower Q-factor than most other outboard bearing cranks, which can increase a rider's efficiency and comfort.
The bottom bracket cups feature special low-friction oversize 6806 bearings for increased stiffness and longer wear life. This is a standard bearing size, so they can be easily replaced when worn, or upgraded to hybrid ceramics. A simple bearing preload adjustment allows for an easy, perfect adjustment.
Extralite takes great pride in producing product that are every bit beautiful as they are functional. Where most manufacturers will take measures to remove machine marks from aluminum surfaces, Extralite exploits their unique machining process to create intricate surface designs and smooth edge transitions. The crank arms are anodized in a glossy black, while the bearing caps and left crank bolt are anodized in gold. Extralite's logos are laser etched on either side of both crank arms.
Installation of the E Bones crankset will require a Shimano Octalink cup tool (such as the TL-UN70), as well as an 8 mm hex wrench. For more information, see Extralite's instruction manual.
